Standaard installatie veroorzaakt fouten en waarschuwingen
goppi reports encountering errors and warnings during a standard Discourse installation on Ubuntu 20, particularly around Let’s Encrypt certificate handling. The logs repeatedly show “error 10 at 3 depth lookup: certificate has expired” related to the DST Root CA X3 certificate, even though the site’s own certs appear valid and expire next year. Nginx also throws a warning: “unable to open supervise/ok: file does not exist” during reload. Despite HTTPS access, browsers flag mixed content (e.g., HTTP images) and lack of verified ownership. Simsnet advises enabling force https in Admin > Settings — but only after confirming full HTTPS functionality to avoid breaking the site. pfaffman confirms the issue stems from a known Let’s Encrypt root certificate problem, expected to be resolved soon, and notes that enabling force_https mitigates the most visible symptoms in the meantime.
Hi there,
I just installed Discourse fresh on a Ubuntu 20 server. I followed the standard installation procedure and noticed a few strange things in the logs inclusive a couple of errors and warnings. I ran the launcher rebuild app a few times on the same day - every time however the log shows after pointing out where the Let’s Encrypt certificates located are the error - i masked the fqdn with “abc”:
-----END CERTIFICATE-----
Your cert is in /shared/letsencrypt/abc/abc.cer
Your cert key is in /shared/letsencrypt/abc/abc.key
The intermediate CA cert is in /shared/letsencrypt/abc/ca.cer
And the full chain certs is there: /shared/letsencrypt/abc/fullchain.cer
O = Digital Signature Trust Co., CN = DST Root CA X3
Using CA: https://acme-v02.api.letsencrypt.org/directory
The script seems than to try to finalize the signing of the certificate and after successfull attempt, i get again the list of certificate locations. The certificates get installed, but when the script restarts nginx, the following error re-appears:
Run reload cmd: sv reload nginx
warning: nginx: unable to open supervise/ok: file does not exist
Reload error for :
Started runsvdir, PID is 4266
Both those tasks are being executed a second round with the same effect.
I can browse to the forum using https albeit the browser informs me that the site is not secure - it says some content such as images are not secure. I also shows in the Security details in Firefox that the website doesn’t supply ownership information and that it’s not specified who verified I guess the certificate. When i click on View certificate everything seems however to be in order - even the expire of the certs is next year.
Any idea what the logs errors/warning could be related to and how to fix them?
Thanks,
Goppi
Go to Admin > Settings and turn on force https. If HTTPS doesn’t fully work on your site, this can break things. Make sure you can access your site over HTTPS before turning this on.
Without this setting, Discourse will load images and other site content as HTTP, causing mixed content warnings on a secure instance.
This is related to an issue with let’s encrypt’s root certificate. I hope that it will be fixed this week. Until then, turning on force_https should solve the worst of the problem.
