The discussion revolves around setting up a second Discourse forum on the same VPS, with the main instance running at https://zbeul.org and the new one at https://mao.zbeul.org. vincent plans to use two standalone instances with a front nginx proxy. pfaffman suggests using Caddy as a reverse proxy to simplify HTTPS setup. vincent asks about running Discourse on non-standard ports and disabling SSL in app.yml, which Falco confirms. riking advises using Unix sockets for internal communication between the proxy and Discourse, and mentions that a multisite setup could reduce resource usage by using a single container.
I would like to host a second forum on an OVH VPS. Main standalone discourse instance runs on the domain root (https://zbeul.org) and I want the new one to be ran on https://mao.zbeul.org.
I figured the best solution would be 2 standalone instances with nginx proxy_pass in front.
Your plan should work. Or both instances on non standard ports. I recommend using caddyserver as the front door. That’ll give you https in both sites with no extra configuration.
Also, if you want to save some resources, you can use this, it’s just a bit more work than 2 standalones, but uses half the resources: Multisite configuration with Docker
