子分类下拉菜单不再包含“全部”选项
Hi,
We just noticed that the subcategories dropdown list now only has a ‘none’ option where it used to also have an ‘all’ option.
Here’s what it looks like now:
Here’s what it looks like on an older installation:
While ‘all’ is still the default value, you can’t return to it after diving into a subcategory, making navigation a little harder. Is this on purpose, or a bug?
2 个赞
Good catch, don’t think this is intentional. If you need to get to “all” you can select “none” first, then reopen the filter.
cc @j.jaffeux
2 个赞
This should fix it, it also introduces tests for category-drop:
https://github.com/discourse/discourse/pull/6743
Will think more about it and maybe improve it more and push it Monday.
7 个赞
Looking good to me, thanks @j.jaffeux. All set here @bartv?
2 个赞
Yep, it works fine for me too. Thanks for the quick solution everyone! :pray:
3 个赞
