Surveys Plugin documentatie?
The discussion revolves around the lack of documentation for the Surveys plugin in Discourse. Nick_Chomey expresses difficulty using the plugin and requests guidance. techAPJ explains that the plugin was custom-built and promises to provide documentation and data explorer queries for viewing results next week. Nick_Chomey asks about viewing survey results and suggests a front-end interface would be beneficial. nathank recommends the Custom Wizard plugin as an alternative, noting its flexibility and data export capabilities, though it has a learning curve. Nick_Chomey appreciates the suggestion and considers it for future use.
I installed the Surveys plugin from the Discourse repo ( discourse/discourse-surveys (github.com)) but can’t figure out how to actually use it. There also doesn’t appear to be any documentation for it here on Meta.
Any tips?
@techAPJ can you shed some light on this plugin please :slight_smile:
The Surveys plugin was written for a customer with their specific use case in mind. I do not have a documentation handy. Will try to write one next week.
@techAPJ Thanks! Could you at least point out how I can even use it? Is there a particular button, menu, markdown code, etc… that allows you to use it? I can’t find anything to even tinker with.
Here’s a basic survey markdown with all available fields:
[survey name="awesome-survey-thumbs" title="Awesome Survey"]
[radio question="Choose any one option:"]
- cat
- dog
[/radio]
[checkbox question="Choose multiple options:"]
- red
- blue
- green
[/checkbox]
[dropdown question="Gender:"]
- Male
- Female
[/dropdown]
[number question="Rate this survey from 1 to 10:"]
[/number]
[textarea question="What is your feedback about xyz?" required="false"]
[/textarea]
[star question="How would you rate overall experience?"]
[/star]
[thumbs question="Were you satisfied with our services?"]
[/thumbs]
[/survey]
Thanks! Very cool!
Where can I see the results? The survey creator (an admin user) only sees the following after submission by a couple users.
It would also be useful if survey responders could see the results as well.
Currently there is no interface to view survey results. I did write some data explorer queries to view survey results. I’ll dig those up and post them along with documentation sometime next week.
ah ok. Thanks. I look forward to seeing the docs! Moreover, if you’re ever able to create some sort of front-end display/interface, that would be fantastic! Until then, I suspect I and most people will have to stick to Polls
You can also use the Custom Wizard plugin for surveys plus more.
Woah, i had no idea that existed. That looks very cool. Its not clear to me how this would provide survey capabilities, but I could definitely make use of it for other things.
You simply use it to ask questions, with most HTML survey stuff supported. The data is collected nicely as a .csv that you can then mess with as much as you like. You can force it upon users (if you wish) or target it nicely.
There is quite a learning curve though.
Thanks very much. I’ll put it on the backburner for now, but good to know it exists!
