Syncing Production to Staging
Given we have different settings on a staging site, mainly
  1. Url is different
  2. Auth0 settings are different and
  3. Email is disabled
    what would be a good way to get the latest data from a production discourse site into a staging site.
I’m thinking.
  1. Export settings via console.
  2. backup production database to s3
  3. restore staging from s3
  4. restore settings via console.
That sounds like a good approach. We have a couple of rake tasks to help with exporting/importing site settings:
rake site_settings:export
and
rake site_settings:import
I’ve also got a ruby app that will upload settings
https://github.com/pfaffman/discourse-settings-uploader
The auth0 config might be as simple as allowing the new site to the auth0 config.
If you don’t configure email, it doesn’t matter if you disable it.
이 문제가 계속 발생하고 있습니다… Don't know how to build task 'site_settings:export'라는 오류가 뜹니다.
이게 매우 늦은 답변이라는 걸 알지만, 향후 참고를 위해, rake를 통해 사용할 수 있으려면 답글을 달고 있는 게시물에 링크된 rake 태스크를 먼저 설정해야 합니다.
