When you use the “edit title and category of this topic” button next to the title or e on the first post, Tab doesn’t do what I expect/hope it to do: Jump to the first input field there, then to the second and so on. Seems the focus stays on where you were before.
Discussion title: [Tab] should work after “edit title” or using hotkeys.
The issue was reported by Sujan, who experienced problems with the Tab key not functioning as expected after using the “edit title and category of this topic” button or the e hotkey. codinghorror suggested explicitly setting focus to improve this. tgxworld initially couldn’t reproduce the issue, but later found that the problem only occurred after using keyboard shortcuts. However, tgxworld mentioned that the issue was already fixed in a commit. The fix is available in this commit.
Sure can we improve this by explicitly setting focus @tgxworld? There is no mobile risk at all.
Re-categorized this to the Contribute > Bug category.
Fixed in
Another bug I found which was quite bad is that opening a composer was sending 3 duplicated requests to the server. This has been fixed in
I can’t reproduce this. Tabbing works fine for me.
@Sujan Thanks for reporting!
You are right, no idea what I saw back then. Problem (that you already fixed) is only present after usage of keyboard shotcuts.
