Tag Selector in Composer not Y-Scrolling
The issue concerns the Tag Selector in the Composer not scrolling vertically on certain Discourse versions. denvergeeks notes that scrolling works on v3.1.0.beta6 +179 but not on the latest release +16, where the Topic Post scrolls instead. Despite the CSS showing overflow-y: auto;, the behavior is inconsistent. denvergeeks later realizes the issue is due to settings—specifically, the default limit of 5 tags shown in the selector. Increasing the max_tags_search_results setting resolves the issue, though they note these settings are not easily found when searching for “tag” or “tags.”
I’ve tested this on several themes including the Default theme.
It still scrolls on my discourse on v3.1.0.beta6 +179
But not on my discourse latest release +16
Instead, the Topic Post behind the Composer does scroll up and down as I move the mouse wheel in within the Tag Selector.
However the Inspector shows it’s set to
overflow-y: auto;
My Bad. There are settings for this…
(Why don’t these settings appear when I search the settings for tag or tags?
Only 5 tags were showing in the selector until I changed these two settings…
From the defaults…
To something larger…
