Ho registrato un modulo UMD su :vendored_pretty_text, ma ho ricevuto errori MiniRacer sul lato server. Dato che funziona correttamente sul lato client, mi rivolgo qui e non al repository del modulo per le issue.
register_asset "vendor/javascripts/j-toml.js", :vendored_pretty_text
MiniRacer::RuntimeError in ComposerMessagesController#index
ReferenceError: TextDecoder is not defined
Rails.root: /var/www/discourse-dev/discourse
Traccia dell'applicazione
lib/pretty_text.rb:127:in `block in create_es6_context'
lib/pretty_text.rb:127:in `create_es6_context'
lib/pretty_text.rb:138:in `block in v8'
lib/pretty_text.rb:136:in `synchronize'
lib/pretty_text.rb:136:in `v8'
lib/pretty_text.rb:178:in `block in markdown'
lib/pretty_text.rb:662:in `block in protect'
lib/pretty_text.rb:662:in `synchronize'
lib/pretty_text.rb:662:in `protect'
lib/pretty_text.rb:177:in `markdown'
lib/pretty_text.rb:302:in `cook'
lib/composer_messages_finder.rb:44:in `check_education_message'
lib/composer_messages_finder.rb:18:in `public_send'
lib/composer_messages_finder.rb:18:in `block in find'
lib/composer_messages_finder.rb:17:in `each'
lib/composer_messages_finder.rb:17:in `find'
app/controllers/composer_messages_controller.rb:9:in `index'
app/controllers/application_controller.rb:420:in `block in with_resolved_locale'
app/controllers/application_controller.rb:420:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:74:in `call'
lib/middleware/gtm_script_nonce_injector.rb:10:in `call'
config/initializers/100-quiet_logger.rb:20:in `call'
config/initializers/100-silence_logger.rb:29:in `call'
lib/middleware/missing_avatars.rb:22:in `call'
lib/middleware/turbo_dev.rb:31:in `call'
Traccia del framework
JavaScript at <anonymous>:1149:23
JavaScript at <anonymous>:15:90
JavaScript at <anonymous>:16:3
mini_racer (0.8.0) lib/mini_racer.rb:228:in `eval_unsafe'
mini_racer (0.8.0) lib/mini_racer.rb:228:in `block (2 levels) in eval'
mini_racer (0.8.0) lib/mini_racer.rb:369:in `timeout'
mini_racer (0.8.0) lib/mini_racer.rb:227:in `block in eval'
mini_racer (0.8.0) lib/mini_racer.rb:225:in `synchronize'
mini_racer (0.8.0) lib/mini_racer.rb:225:in `eval'
/usr/local/lib/ruby/3.2.0/set.rb:511:in `each_key'
/usr/local/lib/ruby/3.2.0/set.rb:511:in `each'
actionpack (7.0.7) lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack (7.0.7) lib/abstract_controller/base.rb:215:in `process_action'
actionpack (7.0.7) lib/action_controller/metal/rendering.rb:165:in `process_action'
actionpack (7.0.7) lib/abstract_controller/callbacks.rb:234:in `block in process_action'
activesupport (7.0.7) lib/active_support/callbacks.rb:118:in `block in run_callbacks'
i18n (1.14.1) lib/i18n.rb:322:in `with_locale'
activesupport (7.0.7) lib/active_support/callbacks.rb:127:in `block in run_callbacks'
activesupport (7.0.7) lib/active_support/callbacks.rb:138:in `run_callbacks'
actionpack (7.0.7) lib/abstract_controller/callbacks.rb:233:in `process_action'
actionpack (7.0.7) lib/action_controller/metal/rescue.rb:23:in `process_action'
actionpack (7.0.7) lib/action_controller/metal/instrumentation.rb:67:in `block in process_action'
activesupport (7.0.7) lib/active_support/notifications.rb:206:in `block in instrument'
activesupport (7.0.7) lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport (7.0.7) lib/active_support/notifications.rb:206:in `instrument'
actionpack (7.0.7) lib/action_controller/metal/instrumentation.rb:66:in `process_action'
actionpack (7.0.7) lib/action_controller/metal/params_wrapper.rb:259:in `process_action'
activerecord (7.0.7) lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack (7.0.7) lib/abstract_controller/base.rb:151:in `process'
actionview (7.0.7) lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler (3.1.1) lib/mini_profiler/profiling_methods.rb:111:in `block in profile_method'
actionpack (7.0.7) lib/action_controller/metal.rb:188:in `dispatch'
actionpack (7.0.7) lib/action_controller/metal.rb:251:in `dispatch'
actionpack (7.0.7) lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
actionpack (7.0.7) lib/action_dispatch/routing/route_set.rb:32:in `serve'
actionpack (7.0.7) lib/action_dispatch/journey/router.rb:50:in `block in serve'
actionpack (7.0.7) lib/action_dispatch/journey/router.rb:32:in `each'
actionpack (7.0.7) lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack (7.0.7) lib/action_dispatch/routing/route_set.rb:852:in `call'
rack (2.2.8) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.8) lib/rack/conditional_get.rb:27:in `call'
rack (2.2.8) lib/rack/head.rb:12:in `call'
actionpack (7.0.7) lib/action_dispatch/http/permissions_policy.rb:38:in `call'
rack (2.2.8) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.8) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (7.0.7) lib/action_dispatch/middleware/cookies.rb:704:in `call'
activerecord (7.0.7) lib/active_record/migration.rb:603:in `call'
actionpack (7.0.7) lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
activesupport (7.0.7) lib/active_support/callbacks.rb:99:in `run_callbacks'
actionpack (7.0.7) lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack (7.0.7) lib/action_dispatch/middleware/executor.rb:14:in `call'
actionpack (7.0.7) lib/action_dispatch/middleware/actionable_exceptions.rb:17:in `call'
actionpack (7.0.7) lib/action_dispatch/middleware/debug_exceptions.rb:28:in `call'
actionpack (7.0.7) lib/action_dispatch/middleware/show_exceptions.rb:29:in `call'
logster (2.12.2) lib/logster/middleware/reporter.rb:43:in `call'
railties (7.0.7) lib/rails/rack/logger.rb:40:in `call_app'
railties (7.0.7) lib/rails/rack/logger.rb:27:in `call'
actionpack (7.0.7) lib/action_dispatch/middleware/remote_ip.rb:93:in `call'
actionpack (7.0.7) lib/action_dispatch/middleware/request_id.rb:26:in `call'
rack (2.2.8) lib/rack/method_override.rb:24:in `call'
actionpack (7.0.7) lib/action_dispatch/middleware/static.rb:23:in `call'
rack (2.2.8) lib/rack/sendfile.rb:110:in `call'
actionpack (7.0.7) lib/action_dispatch/middleware/host_authorization.rb:137:in `call'
rack-mini-profiler (3.1.1) lib/mini_profiler.rb:413:in `call'
message_bus (4.3.8) lib/message_bus/rack/middleware.rb:60:in `call'
railties (7.0.7) lib/rails/engine.rb:530:in `call'
railties (7.0.7) lib/rails/railtie.rb:226:in `public_send'
railties (7.0.7) lib/rails/railtie.rb:226:in `method_missing'
rack (2.2.8) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.8) lib/rack/urlmap.rb:58:in `each'
rack (2.2.8) lib/rack/urlmap.rb:58:in `call'
unicorn (6.1.0) lib/unicorn/http_server.rb:634:in `process_client'
unicorn (6.1.0) lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn (6.1.0) lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn (6.1.0) lib/unicorn/http_server.rb:143:in `start'
unicorn (6.1.0) bin/unicorn:128:in `<top (required)>'
bin/unicorn:96:in `load'
bin/unicorn:96:in `block in <main>'
bin/unicorn:95:in `fork'
bin/unicorn:95:in `<main>'
Traccia completa
Parametri della richiesta
{"composer_action"=>"createTopic"}
Dump della sessione
_csrf_token: "ZW92-YS5C77_SFomhhexLWZl97kxSSfnhJUsCSs5fvY"
session_id: "70bbff56e931ee5388f0edaddb531520"
Dump dell'ambiente
HTTP_ACCEPT: "application/json, text/javascript, */*; q=0.01"
HTTP_ACCEPT_ENCODING: "gzip, deflate, br"
HTTP_ACCEPT_LANGUAGE: "en-US,en;q=0.9,zh-CN;q=0.8,zh;q=0.7"
HTTP_VERSION: "HTTP/1.1"
HTTP_X_CSRF_TOKEN: "gAC9y03LLancuI79CVzQxY6qtmGZCS21KeZJsT1O871UVKrxp7FWnmdeqXu3pSNmF42ouslIYtgb3D683VyXOA"
ORIGINAL_SCRIPT_NAME: ""
REMOTE_ADDR: "127.0.0.1"
SERVER_NAME: "127.0.0.1"
SERVER_PROTOCOL: "HTTP/1.1"
Intestazioni della risposta
Nessuna
