The problem install local ubuntu discourse
after I install discourse in localhost, I use ./discourse-setup. the app build successfully.
but, when I modify app.yml, I add a row "
templates:
  - "templates/web.template.yml
  *- "templates/web.china.template.yml"*
"then ./launcher rebuild app.yml. there is always a problem.
I question chatgpt\grok and deepseek, i can’t solve the problem finally. Here is the certain issue:
FAILED
Pups::ExecError: cd /var/www/discourse && sudo -H -E -u discourse bash -c '
  set -o errexit
  if [ $(git rev-parse --is-shallow-repository) == "true" ]; then
      git remote set-branches --add origin main
      git remote set-branches origin tests-passed
      git fetch --depth 1 origin tests-passed
  else
      git fetch --tags --prune-tags --prune --force origin
  fi
' failed with return #<Process::Status: pid 145 exit 128>
exec failed with the params {"cd"=>"$home", "hook"=>"code", "cmd"=>["sudo -H -E -u discourse git clean -f", "sudo -H -E -u discourse bash -c '\n  set -o errexit\n  if [ $(git rev-parse --is-shallow-repository) == \"true\" ]; then\n      git remote set-branches --add origin main\n      git remote set-branches origin $version\n      git fetch --depth 1 origin $version\n  else\n      git fetch --tags --prune-tags --prune --force origin\n  fi\n'", "sudo -H -E -u discourse bash -c '\n  set -o errexit\n  if [[ $(git symbolic-ref --short HEAD) == $version ]] ; then\n      git pull\n  else\n      git -c advice.detachedHead=false checkout $version\n  fi\n'", "sudo -H -E -u discourse git config user.discourse-version $version", "mkdir -p tmp", "chown discourse:www-data tmp", "mkdir -p tmp/pids", "mkdir -p tmp/sockets", "touch tmp/.gitkeep", "mkdir -p                    /shared/log/rails", "bash -c \"touch -a           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log\"", "bash -c \"ln    -s           /shared/log/rails/{production,production_errors,unicorn.stdout,unicorn.stderr,sidekiq}.log $home/log\"", "bash -c \"mkdir -p           /shared/{uploads,backups}\"", "bash -c \"ln    -s           /shared/{uploads,backups} $home/public\"", "bash -c \"mkdir -p           /shared/tmp/{backups,restores}\"", "bash -c \"ln    -s           /shared/tmp/{backups,restores} $home/tmp\"", "chown -R discourse:www-data /shared/log/rails /shared/uploads /shared/backups /shared/tmp", "[ ! -d public/plugins ] || find public/plugins/ -maxdepth 1 -xtype l -delete"]}
Is there a superman help me? I want to build a traing and Q&A system for my work
Make sure that the formatting of the extra template is exactly like the ones above it. You has asterisks in your code above. I can’t tell if it’s what you’re putting in your app.yml or not.
yes maybe the formatting problem ,the “…china…yml” row code is typing, i forget the asterisks. i will try again. thank you
I just change the language in localazition and refresh, ooh. because i see some guide to build the discourse language , so i try this way . i waste time it is bad
