Het woord STAFF in het Spaans kan veel verwarring veroorzaken
In a discussion about Spanish translations in a forum, Rhod highlights confusion caused by translating “STAFF” as “PERSONAL,” which in Spanish can be misinterpreted as “for personal use” rather than “administrative staff.” This caused initial misunderstanding, especially in categories and user groups. Rhod notes the difficulty in editing this translation due to over 50 non-paginated search results in the admin panel, suggesting pagination would help. muriplz2, a native Spanish speaker, initially didn’t find it confusing but understood the issue after learning the translation. JammyDodger suggests editing groups.default_names.staff or the category slug via the category wrench, though Rhod confirms the search limitation persists. JammyDodger clarifies that changing the category name directly is possible and advises testing visibility to non-staff users. lisandro_iaffar agrees, noting that while “PERSONAL” is technically correct, it’s contextually misleading in forums; recommends using “administrador/es,” which is widely understood in Spanish-speaking communities for this purpose.
Hello, making some changes in the text of my forum I found that STAFF is translated as “PERSONAL” in Spanish, but the word “PERSONAL” is also used within the system, which can create a lot of confusion.
An example is that the default category in English called “STAFF” is for administrators only, but at least at first it confused me and I thought it was a category “for personal use” or something like that, anyway.
I suggest you don’t translate it as “PERSONAL” and just leave it as “STAFF”, or “ADMINISTRADORES”.
On the other hand, the search for words is impossible for me since “PERSONAL” gives me more than 50 results, a pagination in that section would be good.
As a Spanish native that I am, “staff” is not confusing at all and it has never been, where does the “for personal use” meaning come from?
EDIT: Okay, I understood, it’s translated as “PERSONAL” for Spanish. I do find it confusing now
I still speak Spanish natively, at first when I just installed the forum, I saw the “PERSONAL” category and I thought it was a personal section -forgive the redundancy-, but when reading the description I realize that it is really a section for admins, also in the users section appears “PERSONAL” as a translation of “STAFF”, this word was impossible for me to change in the “TEXTS” section within the administration, because more than 50 results appear and it does not allow me to see more of said results , which is why I also suggested paginating the results.
English:
I think that field is groups.default_names.staff if you’d like to rename it for your site in the short term?
(To speed up the change being reflected throughout the menus, etc you may need to run Jobs::EnsureDbConsistency from your /sidekiq/scheduler page :+1:)
Hello, sorry for the late reply, I’ve been busy setting up the forum.
It is not the field to be able to edit the text, I have not been able to find it, since the “Personal” text gives me more than 40 results, I really do not know why the results are not paginated, it would be a good option since it would allow me to find the required text as in my case.
My apologies, I misread this before. If it’s the #staff category name\slug you wish to change rather than the Staff group you can do that from the category wrench. :+1:
I’m not sure how many of the ‘staff’ labels are visible to non-staff users, so you may be able to amend a couple and wait to see if the translation can be changed at the source?
I had to change this translation too :sweat_smile:. Its strictly correct, but in the context of a forum it totally gets confused with the meaning of the word “personal” in the english sense. It’s not confusing when you see it in a physical place, like an hotel or a restaurant, but it’s not appropriate for a forum. As the OP stated, the word “administrador/es” is ubiquitously used in the spanish speaking world for this kind of use.
