Theme Component Matrix
When you have a lot of themes and a lot of theme components it can be hard to ensure that your components are turned on for all the themes you want them to be on for (and only those).
The idea of the Theme Component Matrix is that it would show you at a glance all of your themes and their components. In the mockup I made it just says Yes/No, but those would be links letting you instantly toggle the components.
If there are too many columns, maybe the component names could be rotated with CSS?
「いいね!」 5
@Dannii This is an excellent idea!
Prior to doing anything in core maybe try 2 things:
  1. A data explorer query for this
  2. A theme component that adds Matrix :smiling_face_with_three_hearts:
I worry about adding complexity here to core.
Also on core’s side, I think it makes sense to show a list of “themes” that have a component in the actual customize menu for the component. Just need to be careful not to clutter that UI too much.
「いいね!」 4
このトピックを、このようなデータエクスプローラー クエリを探しているときに見つけました。誰かもう作成しましたか?
テーマとコンポーネントを管理するための UI は、このトピックが開始されてから劇的に改善されました。コンポーネント リストには、各コンポーネントが使用されているすべてのテーマが表示されます。
