Theme Creator Broken Again?
A while ago I’ve experienced issues when editing themes/uploading it to Theme Creator. Got fixed sometime, but the issue came up again. When I tried installing/uploading a theme it gives the the error: You are not permitted to view the requested resource.
Checked console logs. Is this some issue with Theme Creator only allowing admins to upload? Definitely permission-related.
Are you saying you are seeing this screen with a user who is not an admin ? Are you sure of this?
Can you explain, is this error showing up on your site? Are you an admin on your site?
I think @Chaboi_3000 is talking about http://theme-creator.discourse.org/, which allows regular users to create/manage their own themes.
I’ll take a look :eyes:
Yep, was talking about the Theme Creator. Sorry for not making it clear.
Any updates on this? I’m still experiencing this issue and it’s quite frustration considering I don’t have an instance installed on my new computer.
I’m experiencing the same issue, after following the tutorial for themes .
I even registered with two new accounts and both of them get the same issue.
It seems like I don’t have permissions to upload the theme.
:thinking:
Sorry this issue has been open so long! I just pushed a fix for an issue with git themes - can you try again and see if it’s working ok @Chaboi_3000 and @akapetzoglou1
For me it worked now! Thank you @david :rocket:
@david I can confirm it’s fixed and working :tada: Thanks for the time!
This topic was automatically closed after 5 days. New replies are no longer allowed.
