zcuric
(Zdravko)
21 april 2020 om 09:30
1
Hi,
do you guys have suggestion how to approach theme deployment in CI/CD fashion? Client expects new theme releases every two weeks and we would like to ship theme in automated process. We are using discourse docker.
We would like to avoid manual installation for each release.
Side note, I don’t know if this is a bug, but the it seems branch doesn’t get saved on first theme installation. (Need to double check this to confirm)
Thanks
fzngagan
(Faizaan Gagan)
21 april 2020 om 09:52
Its already there. If you install a theme via a git repo, you can update the theme to the latest commit in a single click.
zcuric
(Zdravko)
21 april 2020 om 10:09
3
I know that, but that’s not the way we want to do it.
We want to have dynamic process without touching the discourse admin. I was thinking using themes command discourse/lib/tasks/themes.rake at main · discourse/discourse · GitHub
docker exec -it app rails themes:install -- # theme data
I don’t know if this command can read files. For example - theme.yaml file which would contain theme info for instalation.
That file could be deployed to shared folder and docker command could read it from there and install the theme or make updates.
david
(David Taylor)
21 april 2020 om 10:19
4
@markvanlan recently did some work which might be useful for you
https://github.com/discourse/discourse/commit/f07c4a781c6c054e5d2dc05ab6c0fd0b6cbb0645
There is some usage info in the comments here:
# 2 different formats are accepted:
# == JSON format
# bin/rake themes:install -- '--{"discourse-something": "https://github.com/discourse/discourse-something"}'
# OR
# bin/rake themes:install -- '--{"discourse-something": {"url": "https://github.com/discourse/discourse-something", default: true}}'
# == YAML file formats
# theme_name: https://github.com/example/theme.git
# OR
# theme_name:
# url: https://github.com/example/theme_name.git
# branch: "master"
# private_key: ""
# default: false
# add_to_all_themes: false # only for components - install on every theme
This file has been truncated. show original
zcuric
(Zdravko)
21 april 2020 om 10:24
5
@david thanks, but it doesn’t seem clear to me if I can put path to file as an argument. Would this work?
bin/rake themes:install -- theme.yaml
Maybe I could try.
david
(David Taylor)
21 april 2020 om 10:29
6
I think you would pipe it to STDIN, so something like
cat theme_config.yml | bin/rake themes:install
But I haven’t tested that. Let us know if it works for you
zcuric
(Zdravko)
21 april 2020 om 11:21
7
Your approach works fine. Thanks! Mine doesn’t.
I did experiment a bit with modifying themes.rake by adding
rake themes:install themeFile="theme.yml"
And this:
task "themes:install" => :environment do |task, args|
if ENV['themeFile']
theme_args = YAML.load_file(ENV['themeFile'])
else
theme_args = (STDIN.tty?) ? '' : STDIN.read
use_json = theme_args == ''
theme_args =
begin
use_json ? JSON.parse(ARGV.last.gsub('--', '')) : YAML::load(theme_args)
rescue
puts use_json ? "Invalid JSON input. \n#{ARGV.last}" : "Invalid YML: \n#{theme_args}"
exit 1
log, counts = ThemesInstallTask.install(theme_args)
puts log
puts
puts "Results:"
puts " Installed: #{counts[:installed]}"
puts " Updated: #{counts[:updated]}"
puts " Errors: #{counts[:errors]}"
if counts[:errors] > 0
exit 1
Works fine.
How to run spec for this file?
You should be able to do this:
bin/rake themes:install theme.yml
I added support for passing in JSON, but this code was originally designed to take a yml file as the argument.
zcuric
(Zdravko)
21 april 2020 om 12:30
9
It throws that it’s not valid json
Invalid JSON input.
theme.yml
My theme.yml
test:
url: "https://github.com/discourse/discourse-faria-theme"
I believe that should work! I will look into why it is not working anymore.
Alright, the proper format is bin/rake themes:install < theme.yml. I will document this better in the code
zcuric
(Zdravko)
21 april 2020 om 13:14
12
Nice! Thanks! Glad I could help a bit
