Hello!
I’m trying to upload my theme using the Discourse Theme Creator CLI and I’ve run into a problem.
The README says to use the ‘run’ command. I’m running Discourse in a docker container and unfortunately the run command didn’t exist until recently (see this merged pull request) , so my docker image doesn’t have the new gem in it that allows this command to be run from the command line.
So, I think I need to update the discourse theme ruby gem in order to be able to run this new command. Does anyone have an idea of how I can update it?
I have tried entering the docker container and running these two commands
bundle config unset deployment
bundle exec bundle update --all
But that causes many errors that look like this (for various gems)
An error occurred while installing raindrops (0.20.0), and Bundler cannot continue.
Make sure that `gem install raindrops -v '0.20.0' --source 'https://rubygems.org/'` succeeds before bundling.
I’ve tried installing the gems individually as above but I get another error. I think I may be on the wrong track here so any help would be greatly appreciated.
Thank you! ![]()
