Timeline Action Buttons Overlap Post Footer Actions
Description
The issue occurs in both left-to-right (LTR) and right-to-left (RTL) layouts.
When a page is scrolled toward the bottom of a long post and the viewport width becomes slightly narrower, the two buttons positioned at the bottom of the post timeline—Reply and Post Notifications—continue moving downward and overlap the post footer actions.
On the official Discourse forum, these timeline buttons stop slightly above the post footer actions and do not overlap them. On my forum, however, they stop directly on top of the footer buttons, as shown in the attached screenshot.
Additional Information
  • The issue occurs in both LTR and RTL layouts.
  • The issue is present across multiple themes.
  • A screenshot demonstrating the overlap is attached.
  • The following components are installed:
    • Banner Featured Links
    • Discourse TOC (discotoc)
    • Reader Mode
  • Several plugins are also installed, including an advertisement plugin.
2 לייקים
You’ll have to test in safe mode first and see if it persist. Then try disabling TC and plugins one by one to find the culprit.
לייק 1
Thank you for your guidance. I tested the site in safe mode as suggested, and the issue persisted. After disabling components one by one, I found that the problem was caused by the Google Fonts component.
2 לייקים
