Title prettify should be respecting word breaks (1/4/2011)
סיכום מבוסס בינה מלאכותית
A bug was reported in the title prettify feature, where dates in the format 1/4/2011 were being incorrectly rendered with magic effects. sam demonstrated the issue and filed a bug report. codinghorror noted that the issue might be due to the default SmartyPants implementation. GiraffeSilver suggested using proper ISO 8601 dates instead.
sam investigated the issue further and found the problem in the Redcarpet gem. A fix was proposed and accepted via pull request 507. However, due to the delay in the stable release, sam decided to implement a pure Ruby version of title prettify, which is now included in the code base. The fix is now live, and the title prettify feature respects word breaks correctly.
New Release - Firmware Version 1.02.06 for My Book World Edition I & II (1/4/2011)
Is rendered as:
The :last_quarter_moon_with_face: magic shanaigens should only happen if there is a space between it and other words… EG:
Sam and a 1/4 should get quarter magic
Sam was born 1/4/2001 should get no quarter magic.
לייק 1
I believe this is a default SmartyPants implementation, not our implementation. So the bug might be upstream for existing Ruby code…
The fix is clearly to convince the entire world to using proper (iso 8601) dates. Everything else is just stopgapping.:squinting_face_with_tongue:
Yes, but I daresay there will be more topics about April 1st… :stuck_out_tongue:
3 לייקים
Raised:
https://github.com/vmg/redcarpet/issues/506
the bug is here:
In particular word boundary is defined as: isspace(c) || ispunct(c); , ispunct includes /
לייק 1
Yeah, because David/Gene/Edward does seem like a word break to me. You could specialize it to numbers and say a slash between numbers is not a word break.
fixed via
https://github.com/vmg/redcarpet/pull/507
waiting for it to be accepted
we are carrying a lot of GEM around for this 1 c file out of the 20 it ships
2 לייקים
Change is accepted, waiting on a stable release
2 לייקים
This is now fixed per:
https://github.com/discourse/discourse/commit/ffb8cb8caca2f0b73c480b96a2b753ef5866a91e
We no longer ship the Redcarpet gem, we have a pure Ruby implementation of title prettify that is included in our code base.
Before:
After:
We no longer have to wait months for title prettify fixes.
8 לייקים
