Title - updated and description - no
The theme title and description are not updating correctly when clicking on internal links. Stranik reported the issue and Falco questioned the necessity of updating the description, suggesting it’s mainly for crawlers. Stranik explained that the title updates, but the description remains old. codinghorror suggested simulating Googlebot to see the issue, but Stranik and Stranik reported no change. cpradio provided screenshots of what Googlebot sees, showing the description does update when navigating to a different topic, contradicting Stranik’s initial report.
The theme title and description as on the page
Click on a topic and move on
Why would we update that? That’s for crawlers and they always request a new HTML.
「いいね!」 1
If you do not update the browser and click on links, the title is updated, but the description is not updated.
I don’t know why that would matter, since only crawlers would care about this field? Try changing your user agent to Google’s and browsing the pages, to see what happens.
Strangely, I tried another browser, same thing. It is possible that not changing can affect SEO? When the search engine will pass through the links. They consider this field.
You are not listening. Change your user agent to simulate googlebot.
Changed, nothing has changed. If you have everything working and description changes when you click on internal links, then you can close the topic.
You are not setting Googlebot correctly, this is what Googlebot sees for this topic
And after navigating to a different topic
「いいね!」 6
