TOC op FAQ-pagina?
Hello team, is it possible to add TOC on /faq page?
I’ve already added the TOC component and on the main “faq” topic I see the table of contents, BUT when I go to myforum.com/faq the toc dissappears.
Could it be because the initial topic is in a private category and when discourse calls /faq it brings it up without TOC? :thinking:
This isn’t possible, TOC isn’t compatible with published pages:
Hi SidV!
There is a workaround.
Change the FAQ URL from your site settings:
If you want the page to appear different from a regular topic, you can check out this neat trick:
You can make a regular topic look like a “standalone” page, on which components and plugins will be loaded. :slight_smile:
Wow ! Thanks for this !! :clap:
