Hey thanks for your help it worked (Search banner requires login)
Also the Discourse Top Contributors Sidebar isn’t showing any data for the Anonymous Users
is there anyway i can change that
Does it appear empty like this?
If so, you may need to go to admin → settings and enable enable user directory — it can’t access user data without this setting also being enabled.
it was enabled. Top contributors sidebar doesn’t appear for anonymous users. When signed in the list shows up
As an anonymous visitor, do you see any errors in the developer console on a page where you would expect to see the sidebar? (right click, select inspect, then choose the console tab… errors should appear in red)
It seems an anonymous user can’t access those account profiles for some reason… can you visit those profiles by visiting the URL directly? example.community.com/u/koreaiadmin
I have cleared the issue
Thanks for your help
What was the solution? if you include more details it might help others who may encounter the same problem.
