Top Menu Removal Crashes Site
charles reported that removing all items from the top menu and saving causes the site to “crash” with a blank page. Mittineague asked for clarification on the steps taken and error messages, suggesting that having no navigation is not a normal use case.
charles explained that removing the “latest” menu item causes the issue, and Mittineague agreed that having at least one item is necessary. However, jnns countered that this is a bug, as emptying the settings field renders the site inaccessible.
jnns shared their experience of encountering a 500 error after emptying the settings field and provided logs and source code analysis to support their claim. They suggested implementing a check to prevent deleting all top menu items or adding a validator to ensure the site remains functional.
sam mentioned that a validator has been added, preventing this issue from occurring.
It seems if I remove each item for top menu, save and then try to refresh the main page, it “crashes” and gives me a blank page. If I then go back and reset, the blank page goes back to regular view.
Anyone else having this issue using the latest build?
Exactly what are you removing and how ?
What error message(s) does the console show ?
Under basic setup, I was removing all the items listed under top menu
I’m guessing it “crashes” because when the menu item ‘latest’ is removed, there is no view to show?
Well, you didn’t answer my questions so I can only guess.
You are not removing by using CSS display none, but are emptying this Admin → Settings → Basic Setup input ?
top menu
Determine which items appear in the homepage navigation, and in what order. Example latest|new|unread|categories|top|read|posted|bookmarks
This being empty is not really a Bug as it isn’t normal to have no navigation.
But I think it might be a good idea to force it to have at least one. Or if not that, maybe include a Warning in the copy.
TBH I don’t know how many Warnings Discourse should have. It could make things quite noisy to have a lot of “if you do this weird unusual thing there will be breakage” warnings all over the place.
1 me gusta
Sorry I didn’t answer about the error from console. How can I obtain that for you?
AFAIK most browsers it’s under “tools”
But it might be easier to press F12
Once the dev tools open if it isn’t already open to “console” go to it, reload the page and any JavaScript errors and other messages should show there.
The only item that shows up is
Get http://example.com/ HTTP/1.1 500 Internal Server Error 25ms
As you mentioned it’s not a bug. I will simply reset and instead use CSS display none for category-breadcrumb and the nav-pills
Thanks for looking into it.
1 me gusta
Being able to empty the settings field and the app logic relying on at least one value being present is most definitely a bug as it renders the site inaccessible (at least the index, that is)!
I emptied the settings field and upon the next login was greeted with just an HTTP500 error with no clue on how to resolve this. Only after digging through the logs of the Docker container, finding this:
Redirected to https://discourse.example.com/
Completed 302 Found in 18ms (ActiveRecord: 4.6ms)
Started GET "/" for xxx.xxx.xxx.xxx at 2017-01-26 12:39:52 +0000
NoMethodError (undefined method `name' for nil:NilClass)
/var/www/discourse/app/models/site_setting.rb:65:in `homepage'
and reading up on in in the source code on GitHub
def self.top_menu_items
 top_menu.split('|').map { |menu_item| TopMenuItem.new(menu_item) }
def self.homepage
  top_menu_items[0].name
then I tried to open up the admin panel and was able to set a default value for top_menu_items again.
There needs to be a way to prevent the user from deleting all top_menu_items or a check for an empty setting so that the site keeps being functional.
2 Me gusta
We have a validator now, so this can no longer happen.
3 Me gusta
This topic was automatically closed after 25 hours. New replies are no longer allowed.
