إجراءات الموضوع على الهاتف المحمول مقطوعة بعد التحديث
Hello,
After updating I was met with these options. I like the look of them as they seem very sleek and modern. However, I guess there is not meant to be a close menu button as you can click somewhere on the screen to click off. The menu is too much to the right as there is a gap on the left.
Also the add user note is separated on the post admin menu. Is this because it is a plugin separate to what is meant to be on the menu?
Finally, the make wiki is way too long as it overlays the post count on the bottom right
Thanks :blush:
This is still a little in flux, check with the ineffable @j.jaffeux for details
3 إعجابات
If you pull latest version of the plugin this is fixed.
Can’t repro this, give me more context please. And also I don’t see this issue with this, this is a popover menu, this is meant to be over other elements of the UI.
3 إعجابات
Hey,
Thanks for replying. (I should have mentioned that this is on mobile)
Before we updated it had a x
Now it is like this without a x Additionally, I added a red semi circle to where it is cut off
Yes the x is gone, no plan to have it back ATM.
Are you using some custom css for this menu ? It’s not supposed to display on two columns.
إعجابَين (2)
Ahh, OK thanks for clarification on that :sunglasses:
Just tried in safe mode and it still happens
Oh ok I see this for small mobile screens. Will fix it :+1:
3 إعجابات
Thanks so much Joffrey! :blush:
إعجاب واحد (1)
That should be fixed by:
Thanks :+1:
@awesomerobot note that I removed border-bottom in this case, I think it doesn’t make sense when we show multiple actions per row. Feel free to change if you disagree :stuck_out_tongue:
4 إعجابات
Thanks again! :grinning:
إعجاب واحد (1)
