Topic List Previews (legacy)
Hi, thanks for the great plugin!
Unfortunately, with the last update, the images which do not hosted directly on discourse don’t show up on Grid or Tiles anymore. Could you please check that?
For example, it the post has image from other server (blogger, picasa, …) then they don’t show up anymore. Previously, it works great without any problem.
1 个赞
Thumbnails are now generated by Discourse core and I have little influence over that now.
Much of the thumbnail generation logic has been stripped out and left to Discourse.
You might want to raise that here: Theme modifiers: A brief introduction
2 个赞
Thanks! I just create a reply there. It’s a bit skeptical with all the updates since all my images is not hosted on local server.
2 个赞
I believe it should still work if your ‘uploads’ are hosted on a remote server via settings, but it will no longer hotlink to remote sites and non-affiliated third parties.
It no longer makes sense to manage this part of the code-base in the plugin given it’s now handled by core. It’s absolutely right you follow up with them :+1:
4 个赞
Thanks. I understand the situation. It’s not an easy fix for my site since we’re using other server to host the images. Now it’s too difficult to move to affiliated server with many posts, while it’s too big for hosting on local sever.
1 个赞
The problem I’m having is that when the events plugin is enabled the thumbnails no longer show on mobile as discussed before, I thought this is what you were referring to.
Thumbnails are showing fine for me. Are you sure you’ve updated Events as per @fzngagan?
2 个赞
He must have merged that right after I had tested it, thanks guys, all is working now!
3 个赞
I updated yesterday and I’ve been getting rather poor performance. Digging into the profiler shows me this query by TLP that seems to be the culprit - perhaps there’s an index missing here?
Interestingly enough, this query still shows up when I run the site in safe mode :thinking:
1 个赞
Features Images. This query has not changed in forever (like years!). Are you sure this is a new issue?
Are you ordering by tag created date? That’s almost bound to be a convoluted query. Ordering by Latest will be kinder.
You can always switch this feature off for time being.
The Theme Component uses the core API. You could always switch and use that for time being if it’s hurting you.
1 个赞
It’s new since I upgraded to PG12 I guess. And we do need sorting by tag created date, that’s rather a core ‘feature’ of our community. What would I miss if I switched to the TC?
Ps: I vaguely remember discussing the same issue with the featured row with you years ago, I’ll do some digging.
2 个赞
Are you sure PG 12 upgrade has finished re-indexing? A lot of users were reporting a period of reduced performance whilst this process took place (and those reports were not related to TLP)
Btw actually thinking about it something else might have changed as now has to join with topic_thumbnails, but that was also a while ago and not had any other reports. I suspect before it just used image_url hotlink in the Topic object which would have been faster (one less join) but that’s no longer open to us with core change. That might be contributing.
1 个赞
Yeah, the reindexing has finished. Sorting by topic creation date has the same issue. Here’s the EXPLAIN output for both queries:
Sorted by tagging date:
discourse=# explain SELECT "topics"."id", "topics"."title", "topics"."last_posted_at", "topics"."created_at", "topics"."updated_at", "topics"."views", "topics"."posts_count", "topics"."user_id", "topics"."last_post_user_id", "topics"."reply_count", "topics"."featured_user1_id", "topics"."featured_user2_id", "topics"."featured_user3_id", "topics"."deleted_at", "topics"."highest_post_number", "topics"."like_count", "topics"."incoming_link_count", "topics"."category_id", "topics"."visible", "topics"."moderator_posts_count", "topics"."closed", "topics"."archived", "topics"."bumped_at", "topics"."has_summary", "topics"."archetype", "topics"."featured_user4_id", "topics"."notify_moderators_count", "topics"."spam_count", "topics"."pinned_at", "topics"."score", "topics"."percent_rank", "topics"."subtype", "topics"."slug", "topics"."deleted_by_id", "topics"."participant_count", "topics"."word_count", "topics"."excerpt", "topics"."pinned_globally", "topics"."pinned_until", "topics"."fancy_title", "topics"."highest_staff_post_number", "topics"."featured_link", "topics"."reviewable_score", "topics"."image_upload_id"
discourse-# FROM "topics"
discourse-# INNER JOIN "topic_tags"
discourse-# ON "topic_tags"."topic_id" = "topics"."id"
discourse-# INNER JOIN "tags" ON "tags"."id" = "topic_tags"."tag_id"
discourse-# WHERE ("topics"."deleted_at" IS NULL)
discourse-# AND "topics"."visible" = TRUE
discourse-# AND (NOT topics.closed AND NOT topics.archived AND topics.deleted_at IS NULL)
discourse-# AND (topics.image_upload_id in (
discourse(#         SELECT image_upload_id FROM topic_thumbnails
discourse(#       ))
discourse-# AND (tags.id IN (1))
discourse-#
discourse-# ORDER BY (
discourse(#  SELECT created_at FROM topic_tags
discourse(#         WHERE topic_id = topics.id
discourse(#         AND tag_id IN (1)
discourse(#         LIMIT 1
discourse(# )
discourse-#
discourse-# DESC LIMIT 6;
        QUERY PLAN
 Limit  (cost=2631719.94..2631719.95 rows=6 width=569)
   ->  Sort  (cost=2631719.94..2631721.73 rows=717 width=569)
         Sort Key: ((SubPlan 1)) DESC
         ->  Nested Loop  (cost=0.43..2631707.09 rows=717 width=569)
               ->  Seq Scan on tags  (cost=0.00..4.51 rows=1 width=4)
                     Filter: (id = 1)
               ->  Nested Loop  (cost=0.43..2625737.13 rows=717 width=565)
                     ->  Seq Scan on topic_tags  (cost=0.00..860.33 rows=1539 width=8)
                           Filter: (tag_id = 1)
                     ->  Index Scan using topics_pkey on topics  (cost=0.43..1705.57 rows=1 width=561)
                           Index Cond: (id = topic_tags.topic_id)
                           Filter: ((deleted_at IS NULL) AND visible AND (NOT closed) AND (NOT archived) AND (deleted_at IS NULL) AND (
SubPlan 2))
                           SubPlan 2
                             ->  Seq Scan on topic_thumbnails  (cost=0.00..2966.64 rows=171664 width=8)
               SubPlan 1
                 ->  Limit  (cost=0.29..8.31 rows=1 width=8)
                       ->  Index Scan using index_topic_tags_on_topic_id_and_tag_id on topic_tags topic_tags_1  (cost=0.29..8.31 rows=1
 width=8)
                             Index Cond: ((topic_id = topics.id) AND (tag_id = 1))
 JIT:
   Functions: 25
   Options: Inlining true, Optimization true, Expressions true, Deforming true
(21 rows)
sorted by topic date:
discourse=# explain SELECT "topics"."id", "topics"."title", "topics"."last_posted_at", "topics"."created_at", "topics"."updated_at", "topics"."views", "topics"."posts_count", "topics"."user_id", "topics"."last_post_user_id", "topics"."reply_count", "topics"."featured_user1_id", "topics"."featured_user2_id", "topics"."featured_user3_id", "topics"."deleted_at", "topics"."highest_post_number", "topics"."like_count", "topics"."incoming_link_count", "topics"."category_id", "topics"."visible", "topics"."moderator_posts_count", "topics"."closed", "topics"."archived", "topics"."bumped_at", "topics"."has_summary", "topics"."archetype", "topics"."featured_user4_id", "topics"."notify_moderators_count", "topics"."spam_count", "topics"."pinned_at", "topics"."score", "topics"."percent_rank", "topics"."subtype", "topics"."slug", "topics"."deleted_by_id", "topics"."participant_count", "topics"."word_count", "topics"."excerpt", "topics"."pinned_globally", "topics"."pinned_until", "topics"."fancy_title", "topics"."highest_staff_post_number", "topics"."featured_link", "topics"."reviewable_score", "topics"."image_upload_id" FROM "topics" INNER JOIN "topic_tags" ON "topic_tags"."topic_id" = "topics"."id" INNER JOIN "tags" ON "tags"."id" = "topic_tags"."tag_id" WHERE ("topics"."deleted_at" IS NULL) AND "topics"."visible" = TRUE AND (NOT topics.closed AND NOT topics.archived AND topics.deleted_at IS NULL) AND (topics.image_upload_id in (
      )) AND (tags.id IN (1)) ORDER BY (SELECT created_at FROM topic_tags
        AND tag_id IN (1)
        LIMIT 1)
        DESC LIMIT 6;
        QUERY PLAN
                     Filter: (id = 1)
SubPlan 2))
                           SubPlan 2
               SubPlan 1
 width=8)
 JIT:
   Functions: 25
(21 rows)
2 个赞
Useful. Thanks.
Sorry not sure when I can get to this.
Also be aware the new join might be improved but I cannot get rid of it. (oh yes I could!).
1 个赞
OK I’ve worked with @bartv offline to improve this.
This only affects the Plugin, not the TC:
I recommend upgrading to take advantage as this is a big improvement for sites using Featured Images.
5 个赞
You’re a rockstar! :guitar:
3 个赞
Your detailed sleuthing was critical too, Bart, thanks
3 个赞
Hi, I have added git clone url to containers app.yml but when I go to rebuild app I have error:
(<unknown>): found a tab character that violate indentation while scanning a plain scalar at line 91 column 13 -e LANG=en_US.UTF-8
and website didn’t work.
I have deleted get clone url for the plugin and again it works.
1 个赞
I don’t think your issue is specific to this plugin. You can’t use tabs in your app.yml. Use spaces.
2 个赞
Right, sorry, I have copy-pasted latest line of plugin and changed git clone url. Now it works, thank you :slight_smile:
2 个赞
