Topic List Thumbnails lijkt titels op mobiel te breken
The Topic List Thumbnails theme component is causing title display issues on mobile. jordan-violet shared a screenshot of the issue and provided the component’s settings. jordan-vidrine inquired about the settings and reported that the theme was overriding some of the component’s styles. After investigation, jordan-vidrine found that the issue was not a bug, but rather a compatibility problem between the theme and the component due to conflicting styles. The theme manipulates the topic list, causing conflicts with the component.
Here is what our mobile view looks like when topic list thumbnails is enabled:
Which settings do you have this component set to? Is this a recent thing as well?
We just enabled this theme component yesterday.
		"setting": "default_thumbnail_mode",
		"value": "none"
		"setting": "docs_thumbnail_mode",
		"value": "none"
		"setting": "blog_style_categories",
		"value": "125|59|61|60|71|70|98|62|100|127"
		"setting": "minimal_grid_categories",
		"value": ""
		"setting": "grid_categories",
		"value": ""
		"setting": "masonry_categories",
		"value": ""
		"setting": "list_categories",
		"value": ""
		"setting": "blog_style_tags",
		"value": ""
		"setting": "minimal_grid_tags",
		"value": ""
		"setting": "grid_tags",
		"value": ""
		"setting": "masonry_tags",
		"value": ""
		"setting": "list_tags",
		"value": ""
		"setting": "suggested_topics_mode",
		"value": ""
		"setting": "enable_outside_topic_lists",
		"value": false
		"setting": "placeholder_icon",
		"value": "comments"
		"setting": "mobile_thumbnails",
		"value": true
		"setting": "list_thumbnail_size",
		"value": 200
Thanks, I found the issue. Your site’s theme is styling some of these areas, overriding some of that theme components styles. I will scope the theme down to be in effect when the topic list thumbnail component isnt being used on a category.
Thank you!
Ok so I looked into this. It is not a bug, but an issue with your theme and it’s compatibility with this specific theme component.
Your current them manipulates the topic list a fair amount, and this component does the same. So there are a good bit of conflicting styles fighting each other here.
