主题计时器 - 直接从主题中添加忽略/更改提醒的功能
When a topic reminder is set, it displays “You will be reminded about this topic in xx days” at the bottom. To dismiss it or change it, you have to select the admin wrench, set topic timer, toggle to set user topic timers, then select the red REMOVE TIMER button.
That’s alot of clicks! I’d suggest making the reminder text a link that takes you straight to the user topic timer modal.
12 个赞
