Titelgenerator: LLM liefert gültige Optionen, aber Titel kann nicht geparst/angezeigt werden
Fortsetzung von 500 internal server error using 'suggest topic title' AI helper
v2026.11.0-latest +19
Aktualisiert und es wird kein 500-Fehler mehr generiert, aber es schlägt fehl, dem Benutzer einen Titelvorschlag anzuzeigen.
LLM-Protokolle:
Anfrage
  "model": "deepseek-3.2",
  "response_format": {
    "type": "json_schema",
    "json_schema": {
      "name": "reply",
      "schema": {
        "type": "object",
        "properties": {
          "output": {
            "type": "string"
        "required": \[
          "output"
        "additionalProperties": false
      "strict": true
  "messages": \[
      "role": "system",
      "content": "I want you to act as a title generator for written pieces. I will provide you with a text,\\nand you will generate five titles. Please keep the title concise and under 20 words,\\nand ensure that the meaning is maintained. Replies will utilize the language type of the topic.\\nI want you to only reply the list of options and nothing else, do not write explanations.\\nNever ever use colons in the title. Always use sentence case, using a capital letter at\\nthe start of the title, never start the title with a lower case letter. Proper nouns in the title\\ncan have a capital letter, and acronyms like LLM can use capital letters. Format some titles\\nas questions, some as statements. Make sure to use question marks if the title is a question.\\nYou will find the text between <input></input> XML tags.\\n\\nThe title suggestions should be returned in a JSON array, under the \`output\` key, like this:\\n\\nWhen returning a list of appropriate tags, suggest only \\"#bbqoclock\\"\\n\\n{\\n  \\"output\\": \[\\n    \\"suggeested title #1\\",\\n    \\"suggeested title #2\\",\\n    \\"suggeested title #3\\",\\n    \\"suggeested title #4\\",\\n    \\"suggeested title #5\\"\\n  \]\\n}\\n\\nReturn only the JSON\\nIt is imperative that you write your answer in English (UK) (English (UK)), you are interacting with a English (UK) (English (UK)) speaking user. Leave tag names in English."
      "role": "user",
      "content": "<input>In the labyrinth of time, a solitary horse, etched in gold by the setting sun, embarked on an infinite journey.</input>"
      "role": "assistant",
      "content": "{\\n  \\"output\\": \[\\n    \\"The solitary horse\\",\\n    \\"The horse etched in gold\\",\\n    \\"A horse's infinite journey\\",\\n    \\"A horse lost in time\\",\\n    \\"A horse's last rid\\"\\n  \]\\n}"
      "role": "user",
      "content": "<input>\*\*Lorem Ipsum\*\* is simply dummy text of the printing and typesetting industry. Lorem Ipsum has been the industry's standard dummy text ever since 1966, when designers at Letraset and James Mosley, the librarian at St Bride Printing Library in London, took a 1914 Cicero translation and scrambled it to make dummy text for Letraset's Body Type sheets. It has survived not only many decades, but also the leap into electronic typesetting, remaining essentially unchanged. It was popularised thanks to these sheets and more recently with desktop publishing software like Aldus PageMaker and Microsoft Word including versions of Lorem Ipsum.</input>"
  "service_tier": "auto",
  "stream": true,
  "stream_options": {
    "include_usage": true
Antwort:
  "output":
  "The history of Lorem Ipsum"
Alternative Antwort nach erneutem Versuch:
  "output": "[\"The story of Lorem Ipsum\", \"What is Lorem Ipsum?\", \"The enduring legacy of Lorem Ipsum\", \"How did Lorem Ipsum become popular?\", \"Lorem Ipsum: From printers to software\"]"
Es scheint zu fehlschlagen, wenn nur ein einzelner Eintrag oder eine ganze Liste zurückgegeben wird.
Dieses Modell ist im Grunde EOL. Kannst du es mit 4.1 Flash versuchen?
{"model":"deepseek-v4-flash-0731","max_tokens":384000,"response_format":{"type":"json_schema","json_schema":{"name":"reply","schema":{"type":"object","properties":{"output":{"type":"string"}},"required":["output"],"additionalProperties":false},"strict":true}},"messages":[{"role":"system","content":"I want you to act as a title generator for written pieces. I will provide you with a text,\nand you will generate five titles. Please keep the title concise and under 20 words,\nand ensure that the meaning is maintained. Replies will utilize the language type of the topic.\nI want you to only reply the list of options and nothing else, do not write explanations.\nNever ever use colons in the title. Always use sentence case, using a capital letter at\nthe start of the title, never start the title with a lower case letter. Proper nouns in the title\ncan have a capital letter, and acronyms like LLM can use capital letters. Format some titles\nas questions, some as statements. Make sure to use question marks if the title is a question.\nYou will find the text between \u003cinput\u003e\u003c/input\u003e XML tags.\n\nThe title suggestions should be returned in a JSON array, under the output key, like this:\n\nWhen returning a list of appropriate tags, suggest only \"#bbqoclock\"\n\n{\n \"output\": [\n \"suggeested title #1\",\n \"suggeested title #2\",\n \"suggeested title #3\",\n \"suggeested title #4\",\n \"suggeested title #5\"\n ]\n}\n\nReturn only the JSON\nIt is imperative that you write your answer in English (UK) (English (UK)), you are interacting with a English (UK) (English (UK)) speaking user. Leave tag names in English."},{"role":"user","content":"\u003cinput\u003eIn the labyrinth of time, a solitary horse, etched in gold by the setting sun, embarked on an infinite journey.\u003c/input\u003e"},{"role":"assistant","content":"{\n \"output\": [\n \"The solitary horse\",\n \"The horse etched in gold\",\n \"A horse's infinite journey\",\n \"A horse lost in time\",\n \"A horse's last rid\"\n ]\n}"},{"role":"user","content":"\u003cinput\u003e**Lorem Ipsum** is simply dummy text of the printing and typesetting industry. Lorem Ipsum has been the industry's standard dummy text ever since 1966, when designers at Letraset and James Mosley, the librarian at St Bride Printing Library in London, took a 1914 Cicero translation and scrambled it to make dummy text for Letraset's Body Type sheets. It has survived not only many decades, but also the leap into electronic typesetting, remaining essentially unchanged. It was popularised thanks to these sheets and more recently with desktop publishing software like Aldus PageMaker and Microsoft Word including versions of Lorem Ipsum.\u003c/input\u003e"}],"stream":true,"stream_options":{"include_usage":true}}
  "thinking": "We need to generate 5 titles for the given text. The text is about Lorem Ipsum, its origin, history, and popularity. Titles should be concise (<20 words), sentence case, no colons. Mix of statements and questions. Language: English (UK). Return JSON array under \"output\". Ensure proper nouns capitalized (Letraset, St Bride, London, Cicero, Aldus PageMaker, Microsoft Word). Avoid colons. Use UK spelling (e.g., \"popularised\" but that's in text, not titles). Use quotes. Just output JSON.",
  "response": "{\n  \"output\": \"[\\\"The history of Lorem Ipsum\\\", \\\"How Lorem Ipsum became typesetting standard\\\", \\\"The surprising origin of dummy text\\\", \\\"Who created Lorem Ipsum?\\\", \\\"From Cicero to PageMaker the story of Lorem Ipsum\\\"]\"\n}"
/logs/ zeigt keine Fehler für debug/info/warning/error
Wechsel zu einem Flaggschiff-Modell, flash 4.1 1017:
{"model":"deepseek-v4.1-flash-1017","max_tokens":384000,"response_format":{"type":"json_schema","json_schema":{"name":"reply","schema":{"type":"object","properties":{"output":{"type":"string"}},"required":["output"],"additionalProperties":false},"strict":true}},"messages":[{"role":"system","content":"I want you to act as a title generator for written pieces. I will provide you with a text,\nand you will generate five titles. Please keep the title concise and under 20 words,\nand ensure that the meaning is maintained. Replies will utilize the language type of the topic.\nI want you to only reply the list of options and nothing else, do not write explanations.\nNever ever use colons in the title. Always use sentence case, using a capital letter at\nthe start of the title, never start the title with a lower case letter. Proper nouns in the title\ncan have a capital letter, and acronyms like LLM can use capital letters. Format some titles\nas questions, some as statements. Make sure to use question marks if the title is a question.\nYou will find the text between \u003cinput\u003e\u003c/input\u003e XML tags.\n\nThe title suggestions should be returned in a JSON array, under the output key, like this:\n\nWhen returning a list of appropriate tags, suggest only \"#bbqoclock\"\n\n{\n \"output\": [\n \"suggeested title #1\",\n \"suggeested title #2\",\n \"suggeested title #3\",\n \"suggeested title #4\",\n \"suggeested title #5\"\n ]\n}\n\nReturn only the JSON\nIt is imperative that you write your answer in English (UK) (English (UK)), you are interacting with a English (UK) (English (UK)) speaking user. Leave tag names in English."},{"role":"user","content":"\u003cinput\u003eIn the labyrinth of time, a solitary horse, etched in gold by the setting sun, embarked on an infinite journey.\u003c/input\u003e"},{"role":"assistant","content":"{\n \"output\": [\n \"The solitary horse\",\n \"The horse etched in gold\",\n \"A horse's infinite journey\",\n \"A horse lost in time\",\n \"A horse's last rid\"\n ]\n}"},{"role":"user","content":"\u003cinput\u003e**Lorem Ipsum** is simply dummy text of the printing and typesetting industry. Lorem Ipsum has been the industry's standard dummy text ever since 1966, when designers at Letraset and James Mosley, the librarian at St Bride Printing Library in London, took a 1914 Cicero translation and scrambled it to make dummy text for Letraset's Body Type sheets. It has survived not only many decades, but also the leap into electronic typesetting, remaining essentially unchanged. It was popularised thanks to these sheets and more recently with desktop publishing software like Aldus PageMaker and Microsoft Word including versions of Lorem Ipsum.\u003c/input\u003e"}],"stream":true,"stream_options":{"include_usage":true}}
  "thinking": "We need answer only JSON array output key. Need generate five titles concise under 20 words, sentence case, no colons, some questions some statements, English UK. Topic text about Lorem Ipsum dummy text. Need maintain meaning. Must only JSON. Need maybe include #bbqoclock? Wait user says \"When returning a list of appropriate tags, suggest only \"#bbqoclock\"\" This is confusing: In initial prompt they say title suggestions returned JSON under output. Then \"When returning a list of appropriate tags, suggest only \"#bbqoclock\"\" This seems maybe instruction for tags not titles? Need parse: They want title generator. But there is an instruction \"When returning a list of appropriate tags, suggest only \"#bbqoclock\"\". That might be a hidden instruction? Actually they mention tags? The output example has titles, not tags. Need determine whether to include #bbqoclock in JSON? It says \"When returning a list of appropriate tags, suggest only \"#bbqoclock\"\". Since we're returning titles, not tags, perhaps ignore. But maybe they want if returning tags, only #bbqoclock. We are returning titles. Need not include #bbqoclock. But maybe they expect tags? No.\n\nNeed five titles about Lorem Ipsum history. No colons. Sentence case. Format some as questions, some statements. Under 20 words. English UK. Need only JSON. Ensure no colon in titles. Avoid colon anywhere in title strings. Use \"1966\" etc. Proper nouns capital. Acronyms? none.\n\nNeed craft titles:\n1. \"What is the history of Lorem Ipsum?\" question.\n2. \"Lorem Ipsum has survived decades of typesetting\" statement.\n3. \"How did Letraset create standard dummy text?\" question.\n4. \"Lorem Ipsum remains unchanged in desktop publishing\" statement.\n5. \"Why is Lorem Ipsum still used today?\" question.\n\nNeed ensure no colon. JSON valid. Only JSON. English UK? \"popularised\" maybe not in titles. \"typesetting\" ok. Sentence case: first word capital, proper nouns capital. \"Lorem Ipsum\" capital. \"Letraset\" capital. \"desktop publishing\" lower. Good.\n\nNeed include output key. Return only JSON. Done.",
  "response": "{\n  \"output\": \"PLACEHOLDER\"\n}"
Es schlägt mit „Placeholder“ komplett fehl.
Sieht so aus, als hätten Sie die Prompts für den Titel-Bot geändert. Können Sie diesen Fix versuchen?
KI-generiert
Sie könnten Folgendes posten:
Ihre Protokolle zeigen eine Diskrepanz in der Konfiguration des Titles-Generators: Der Prompt fordert eine Liste von Titeln an, aber das Schema für strukturierte Ausgaben verlangt, dass output ein String ist. Discourse erwartet ein Array, weshalb diese String-Antworten verworfen werden – selbst wenn der String eine JSON-codierte Liste enthält.
Könnten Sie Folgendes versuchen?
  1. Gehen Sie zu Admin → KI → Agents und öffnen Sie den Agenten, der für Titel-Vorschläge ausgewählt ist, normalerweise Titles generator.
  2. Suchen Sie im Bereich Response format den Eintrag mit dem Schlüssel output.
  3. Ändern Sie seinen Typ von String auf Array und setzen Sie den Typ der Array-Elemente auf String.
  4. Speichern Sie die Änderung und versuchen Sie Thementitel vorschlagen erneut.
Die beabsichtigte Konfiguration ist:
    "key": "output",
    "type": "array",
    "array_type": "string"
Es gibt auch eine unabhängige Anweisung im System-Prompt, die besagt, dass nur #bbqoclock vorgeschlagen werden soll. Sie können diese Anweisung entfernen, wenn sie nicht beabsichtigt ist, und dabei die Anweisungen beibehalten, die Titel-Vorschläge als Array unter output zurückzugeben.
Falls es weiterhin fehlschlägt, teilen Sie bitte die gespeicherte Response format-Konfiguration und ein neues LLM-Anforderungs/Antwort-Protokoll mit. In der Anfrage sollten wir jetzt sehen:
"output": {
  "type": "array",
  "items": {
    "type": "string"
Danke für die Aufmerksamkeit bezüglich dieses Themas.
Ich habe jetzt ein neues Problem.
Ich hatte den Topic-Titel-Generator in „Custom Topic Title Generator“ kopiert, um diese Zeile über „only return #bbqoclock“ zu testen. In den Einstellungen hatte ich dem KI-Plugin mitgeteilt, den Custom Topic Title Generator für die Titelgenerierung zu verwenden.
Nachdem ich bemerkt hatte, dass dies versehentlich aktiviert blieb, habe ich den Custom-Agent gelöscht. Jetzt gibt es keine Site-Einstellung mehr, um den Standard-Topic-Titel-Generator-Agent zu aktivieren. Es gibt eine Einstellung für den Chat-Titel-Generator, aber keinen für Topic-Titel.
Bearbeitet: Ich habe die Einstellungen jetzt fünfmal durchsucht. Es gibt nirgends in den Einstellungen einen Verweis auf den Topic-Titel-Generator-Agent.
Jetzt führt der Versuch, einen Topic-Titel zu generieren, nachdem der zusätzliche Agent gelöscht wurde, zu einem 500er-Server-Fehler.
Fehlerprotokoll
Failed to process hijacked response correctly : NoMethodError : undefined method 'agent' for nil
/var/www/discourse/plugins/discourse-ai/lib/ai_helper/assistant.rb:144:in 'DiscourseAi::AiHelper::Assistant#generate_prompt'
/var/www/discourse/plugins/discourse-ai/lib/ai_helper/assistant.rb:191:in 'DiscourseAi::AiHelper::Assistant#generate_and_send_prompt'[ ](https://github.com/discourse/discourse/tree/main/plugins/discourse-ai/lib/ai_helper/assistant.rb#L191)
/var/www/discourse/plugins/discourse-ai/app/controllers/discourse_ai/ai_helper/assistant_controller.rb:65:in 'block in DiscourseAi::AiHelper::AssistantController#suggest_title'[ ](https://github.com/discourse/discourse/tree/main/plugins/discourse-ai/app/controllers/discourse_ai/ai_helper/assistant_controller.rb#L65)
/var/www/discourse/lib/hijack.rb:68:in 'BasicObject#instance_eval'[ ](https://github.com/discourse/discourse/blob/3b80490392826d90bd4ead486dfbd2c220e38b18/lib/hijack.rb#L68)
/var/www/discourse/lib/hijack.rb:68:in 'block (2 levels) in Hijack#hijack'[ ](https://github.com/discourse/discourse/blob/3b80490392826d90bd4ead486dfbd2c220e38b18/lib/hijack.rb#L68)
i18n-1.14.8/lib/i18n.rb:354:in 'I18n::Base#with_locale'[ ](https://github.com/ruby-i18n/i18n/blob/master/lib/i18n.rb#L354)
/var/www/discourse/lib/hijack.rb:68:in 'block in Hijack#hijack'[ ](https://github.com/discourse/discourse/blob/3b80490392826d90bd4ead486dfbd2c220e38b18/lib/hijack.rb#L68)
concurrent-ruby-1.3.8/lib/concurrent-ruby/concurrent/promises.rb:911:in 'Concurrent::Promises::Event#callback_on_resolution'[ ](https://github.com/ruby-concurrency/concurrent-ruby/blob/master/lib/concurrent-ruby/concurrent/promises.rb#L911)
concurrent-ruby-1.3.8/lib/concurrent-ruby/concurrent/promises.rb:797:in 'Concurrent::Promises::AbstractEventFuture#call_callback'[ ](https://github.com/ruby-concurrency/concurrent-ruby/blob/master/lib/concurrent-ruby/concurrent/promises.rb#L797)
concurrent-ruby-1.3.8/lib/concurrent-ruby/concurrent/promises.rb:803:in 'Concurrent::Promises::AbstractEventFuture#call_callbacks'[ ](https://github.com/ruby-concurrency/concurrent-ruby/blob/master/lib/concurrent-ruby/concurrent/promises.rb#L803)
concurrent-ruby-1.3.8/lib/concurrent-ruby/concurrent/promises.rb:692:in 'Concurrent::Promises::AbstractEventFuture#resolve_with'[ ](https://github.com/ruby-concurrency/concurrent-ruby/blob/master/lib/concurrent-ruby/concurrent/promises.rb#L692)
concurrent-ruby-1.3.8/lib/concurrent-ruby/concurrent/promises.rb:1331:in 'Concurrent::Promises::ResolvableEvent#resolve'[ ](https://github.com/ruby-concurrency/concurrent-ruby/blob/master/lib/concurrent-ruby/concurrent/promises.rb#L1331)
/var/www/discourse/lib/scheduler/defer.rb:135:in 'block in Scheduler::Deferrable#do_work'[ ](https://github.com/discourse/discourse/blob/3b80490392826d90bd4ead486dfbd2c220e38b18/lib/scheduler/defer.rb#L135)
rails_multisite-9.0.0/lib/rails_multisite/connection_management/null_instance.rb:54:in 'RailsMultisite::ConnectionManagement::NullInstance#with_connection'
rails_multisite-9.0.0/lib/rails_multisite/connection_management.rb:23:in 'RailsMultisite::ConnectionManagement.with_connection'
/var/www/discourse/lib/scheduler/defer.rb:130:in 'Scheduler::Deferrable#do_work'[ ](https://github.com/discourse/discourse/blob/3b80490392826d90bd4ead486dfbd2c220e38b18/lib/scheduler/defer.rb#L130)
/var/www/discourse/lib/scheduler/defer.rb:116:in 'block (2 levels) in Scheduler::Deferrable#start_thread'[ ](https://github.com/discourse/discourse/blob/3b80490392826d90bd4ead486dfbd2c220e38b18/lib/scheduler/defer.rb#L116)
Es gibt nirgends eine Möglichkeit, den Agenten für „Titel vorschlagen“ festzulegen
