Hello!
We’ve set up the AI plugin with Google Gemini 2.0 Flash and enabled summarize, spam detection, and AI helper.
Helper and spam seem to work fine - no problems at all there.
However, the summarize just hangs
Error log shows the below -
DiscourseAi::Completions::Endpoints::Gemini: status: 400 - body: {
"error": {
"code": 400,
"message": "Invalid value at 'generation_config.response_schema.type' (type.googleapis.com/google.ai.generativelanguage.v1beta.Type), \"json_schema\"\nInvalid JSON payload received. Unknown name \"json_schema\" at 'generation_config.response_schema': Cannot find field.",
"status": "INVALID_ARGUMENT",
"details": [
"@type": "type.googleapis.com/google.rpc.BadRequest",
"fieldViolations": [
"field": "generation_config.response_schema.type",
"description": "Invalid value at 'generation_config.response_schema.type' (type.googleapis.com/google.ai.generativelanguage.v1beta.Type), \"json_schema\""
"field": "generation_config.response_schema",
"description": "Invalid JSON payload received. Unknown name \"json_schema\" at 'generation_config.response_schema': Cannot find field."
I have no experience with this, so any input is appreciated. It’s only the summarize feature that’s not working, everything else seems fine.
Thanks in advance
