Translation problem, using AAAA instead of YYYY
Hi, I’m observing an annoying problem in some Brazilian Portuguese-speaking discourse forums for quite some time. See the following:
I.E. Instead of the year, it contains “AMAMAMAM” or “PMPMPMPM”. This happens due to a bad date format string. Going in the source, I located it at line 11 of discourse/config/locales/server.pt_BR.yml at main · discourse/discourse · GitHub.
It should be YYYY instead of AAAA. I already submitted a fix to transifex. How/when are those fixes published?
Use Admin - Customize - Text to fix them immediately.
I updated the translations, so this should be fixed.
This topic was automatically closed 24 hours after the last reply. New replies are no longer allowed.
