The user pfaffman is experiencing an issue with their dashboard plugin after updating to Discourse 2.9.0.beta5, resulting in an ActiveSupport::MessageEncryptor::InvalidMessage error. The error appears to be related to the MessageEncryptor default serializer changing from Marshal to JSON in Rails 7. Gerhard suggests that the update to Rails 7 is the likely cause.
After researching, pfaffman discovers that setting config.active_support.default_message_encryptor_serializer = :marshal in config/application.rb should resolve the issue, but this does not work in their development environment.
Further investigation reveals that the issue may be related to the key generator digest class changing from SHA1 to SHA256. However, pfaffman finds that the hash_digest_class is the same in both their working and broken environments.
Ultimately, pfaffman resolves the issue by adding the old cipher to the MessageEncryptor initialization: cipher: "aes-256-cbc". The reason for the different results between the two instances running 7.0.3 remains unclear, but pfaffman is able to resolve the issue with the help of the Rails upgrade documentation.
The update to 2.9.0.beta5 is causing an issue with my dashboard plugin. Something is triggering an error on one view of the plugin:
Started GET "/pfaffmanager/servers" for 73.147.117.173 at 2022-06-14 17:53:31 +0000
Processing by Pfaffmanager::ServersController#index as HTML
Rendered default/empty.html.erb within layouts/application (Duration: 0.1ms | Allocations: 29)
Rendered layout layouts/application.html.erb (Duration: 21.6ms | Allocations: 7109)
Completed 200 OK in 142ms (Views: 23.0ms | ActiveRecord: 0.0ms | Allocations: 37464)
Started GET "/chat/chat_channels.json" for 73.147.117.173 at 2022-06-14 17:53:31 +0000
Processing by DiscourseChat::ChatChannelsController#index as JSON
Started GET "/presence/get?channels%5B%5D=%2Fchat-user%2Fchat%2F1&channels%5B%5D=%2Fchat-user%2Fcore%2F1" for 73.147.117.173 at 2022-06-14 17:53:31 +0000
Processing by PresenceController#get as JSON
Parameters: {"channels"=>["/chat-user/chat/1", "/chat-user/core/1"]}
Completed 200 OK in 44ms (Views: 1.9ms | ActiveRecord: 0.0ms | Allocations: 5134)
Completed 200 OK in 94ms (Views: 0.3ms | ActiveRecord: 0.0ms | Allocations: 22124)
Processing by Pfaffmanager::ServersController#index as JSON
Completed 500 Internal Server Error in 113ms (ActiveRecord: 0.0ms | Allocations: 15487)
ActiveSupport::MessageEncryptor::InvalidMessage (ActiveSupport::MessageEncryptor::InvalidMessage)
(eval):9:in `_fast_attributes'
app/controllers/application_controller.rb:543:in `render_json_dump'
app/controllers/application_controller.rb:415:in `block in with_resolved_locale'
app/controllers/application_controller.rb:415:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:71:in `call'
lib/middleware/anonymous_cache.rb:368:in `call'
config/initializers/008-rack-cors.rb:25:in `call'
config/initializers/100-quiet_logger.rb:23:in `call'
config/initializers/100-silence_logger.rb:31:in `call'
lib/middleware/enforce_hostname.rb:23:in `call'
lib/middleware/request_tracker.rb:202:in `call'
This appears to have only in the index view of my plugin, not in any other pages in the plugin or Discourse. I’m not sure where to look. So glad I ran the upgrade on my staging site first!
The above suggested to me that this has to do with the chat plugin, but it’s happening on my dev instance without chat installed.
Wow, and searching google fro ActiveSupport::MessageEncryptor::InvalidMessage "fast_attributes" returns only this topic!
Is there some way that you know off the top of your head that I can ignore this change in my existing plugin with some obvious-once-you-know-it line in my plugin.rb?
Or maybe I’m going to have to figure out what this means.
EDIT: but on dev adding that line to config/application.rb is not a magic fix.
Sorry. I read a bit further:
So maybe that will solve my immediate problem. Thanks again for your help! Maybe I’ll get it this time.
Well, the key I generate for both rails 6 and rails 7 looks like this:
but they encrypt things differently. I was hoping that the hash_digest_class was the issue, but it at least looks like it’s the same on both, but the encrypted string is different.
Oh. Darn. No, that’s not it. My production site that’s working is on 7.0.3 and the staging site that’s broken is also on 7.0.3. It’s encrypting stuff differently. I can’t tell, and don’t know how to tell, if it’s that the serializer is differnt or the cypher is different.
Meanwhile, I’ve learned that 7.0 supports encrpypting fields, which will let me rip out some custom code if only I can figure out how to access my encrypted API keys at all. Or maybe I’ll just trash and regenerate them.
As of latext I am getting encryptions like => "SUNBZlRURThEZjdVUG8wTzV1eWk0dz09LS1uRGVSQWtPRU9rc1ZCa1Y1d2pyeU5nPT0=--43eab316e6a9ebafc72d4982347abd9c7f6605db"
with 2.9.0.beta4 they look like "FwL/GGvrDHOpQ1bnGiI=--kCLbUxMf/XeMaeWF--/feRN+/l1q3EFdKgyIo+7Q==
k = ActiveSupport::MessageEncryptor.new(KEY, cipher: "aes-256-cbc")
I still don’t understand why the two instances that both claim to be running 7.0.3 have different results, but a good RTFM of the upgrade docs was a big help. Thanks, Gerhard! It was the nudge I needed.
