Problemen met hbs ValueList als niet-admin--wat te gebruiken in plaats daarvan?
I’ve got code on my https://dashboard.literatecomputing.com/ that works as admin (and has worked for a long while as regular users, I’m pretty sure) that is now failing as a regular user.
When I include this code on the page, it works as an admin, but not as a regular user:
        <ValueList
          @values={{this.server.custom_plugins}}
          @inputType="array"
          @addKey="pfaffmanager.server.custom_plugins_suggestion"
I checked that the regular user has access to this.server.custom_plugins and
What strikes me as strange is that if I hit the page as a regular user, the page renders nothing, not even the {{log ...}} lines in the hbs that do log if the errant lines are removed.
Error occurred:
- While rendering:
  -top-level
    application
      discourse-root
        pfaffmanager
          pfaffmanager.servers
            pfaffmanager.servers.edit
And another <ValueList..> is also causing the same problem. Is there something else I should use? I think that I thought . . . wait. The only place I see <ValueList> is in a admin component.
https://github.com/discourse/discourse/blob/main/app/assets/javascripts/admin/addon/components/admin-user-field-item.hbs#L29
I’m using this selector to allow users to select plugins, like this:
I can’t remember what I was doing before. I think I did this for the Ember 5 upgrade?
Is there something else I should do?
EDIT: I guess <ValueList is only for admins and now I have a vague memory of creating my own valueList and then wondering why I’d done so and deleting it.
I found the PvalueList that I had created before (and had just copied from the value-ilist in admin) and restored it from github.
