Hi, upgrading seem to get stuck at the same point. I am not a docker knowledgeable person.truly appreciate if you can tell me what to do.
Log in to your server via the console or ssh and
cd /var/discourse
./launcher rebuild app
Thanks Jay! I will ssh tomorrow. Truly appreciate your response on a weekend!
Regards,
shanthala
Hi Jay, I puTTYed into the console and entered the two commands you suggested. I get the message saying verify it is running and you have access.
Appreciate your advise.
Great! So glad you got it done.
Thanks again for the advice and instructions!
