Troubleshooting bootstrap failures in Discourse
Thomas_Rother is troubleshooting bootstrap failures in Discourse due to a multipart-post gem conflict during db:migrate. The issue arises from a plugin, discourse-workflow, which depends on an outdated version of multipart-post-2.4.0, conflicting with the newer 2.4.1 version bundled in Discourse. The problem is resolved when the plugin author, merefield, removes the conflicting dependency. The discussion highlights the impact of Discourse’s new bundled gem management, where plugins must now rely on core dependencies instead of shipping their own versions. Thomas_Rother confirms the fix works after updating to the latest discourse-workflow commit 6be7a44.
I am still struggling with the new “pre-bundling” process. The bootstrap fails on my test instance and I dont know why. Note that this is is a setup with an external postgres database. The containers run behind a haproxy as ssl accelerator. I only bootstrap the web_only container here. The current build version (before the bootstrap) is 3.5.0.beta8-dev, Commits · discourse/discourse · GitHub
This is the currently failing yml:
# IMPORTANT: SET A SECRET PASSWORD in Postgres for the Discourse User
# TODO: change SOME_SECRET in this template
templates:
  ## Uncomment the next line to enable the IPv6 listener
  #- "templates/web.ipv6.template.yml"
  - "templates/web.socketed.template.yml"
  #- "templates/web.ssl.template.yml"
  #- "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
  - "80:80"   # http
  - "443:443" # https
# Use 'links' key to link containers together, aka use Docker --link flag.
links:
  - link:
      alias: data
# any extra arguments for Docker?
# docker_args:
params:
  #version: tests-passed
env:
  LC_ALL: en_US.UTF-8
  LANG: en_US.UTF-8
  LANGUAGE: en_US.UTF-8
  DISCOURSE_DEFAULT_LOCALE: de
  UNICORN_WORKERS: 4
  DISCOURSE_HOSTNAME: 'forum2.netzwissen.de'
  ## Uncomment if you want the container to be started with the same
  ## hostname (-h option) as specified above (default "$hostname-$config")
  #DOCKER_USE_HOSTNAME: true
  DISCOURSE_DEVELOPER_EMAILS: 'admin@netzwissen.de'
  ## TODO: The SMTP mail server used to validate new accounts and send notifications
  # SMTP ADDRESS, username, and password are required
  # WARNING the char '#' in SMTP password can cause problems!
  DISCOURSE_SMTP_ADDRESS: mail.netzwissen.de
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: discourse@netzwissen.de
  DISCOURSE_SMTP_PASSWORD: [xxxxxxxxxxxxxxxxx}
  #DISCOURSE_SMTP_ENABLE_START_TLS: true           # (optional, default true)
  #DISCOURSE_SMTP_DOMAIN: discourse.example.com    # (required by some providers)
  DISCOURSE_NOTIFICATION_EMAIL: discourse@netzwissen.de    # (address to send notifications from)
  ## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
  #LETSENCRYPT_ACCOUNT_EMAIL: me@example.com
## configure connectivity to the databases
  DISCOURSE_DB_SOCKET: ''
  DISCOURSE_DB_USERNAME: [xxxxxxxxxxx]
  DISCOURSE_DB_NAME: [xxxxxxxxxxxxxxx]
  DISCOURSE_DB_HOST: [xxxxxxxxxxxxxxx]
  DISCOURSE_DB_PASSWORD: [xxxxxxxxxxxxxxx]
  ## redis caching on the neighbouring container
  DISCOURSE_REDIS_HOST: redis
  ## The http or https CDN address for this Discourse instance (configured to pull)
  ## see https://meta.discourse.org/t/14857 for details
  ## The maxmind geolocation IP account ID and license key for IP address lookups
  ## see https://meta.discourse.org/t/-/173941 for details
  #DISCOURSE_MAXMIND_ACCOUNT_ID: 123456
  #DISCOURSE_MAXMIND_LICENSE_KEY: 1234567890123456
volumes:
  - volume:
      host: /mnt/data/discourse/shared/web-only
      guest: /shared
  - volume:
      host: /mnt/data/discourse/shared/web-only/log/var-log
      guest: /var/log
## Plugins go here
hooks:
  after_code:
    - exec:
        cd: $home/plugins
        cmd:
          - git clone https://github.com/discourse/discourse-shared-edits.git
# some plugins are removed, as they are now bundled with core
# https://meta.discourse.org/t/bundling-more-popular-plugins-with-discourse-core/373574
## = now bundled
##          - git clone https://github.com/discourse/discourse-chat-integration.git
##          - git clone https://github.com/discourse/discourse-openid-connect.git
##          - git clone https://github.com/discourse/discourse-calendar.git
##          - git clone https://github.com/angusmcleod/discourse-events.git
##          - git clone https://github.com/discourse/discourse-data-explorer.git
##          - git clone https://github.com/discourse/discourse-reactions.git
##          - git clone https://github.com/discourse/discourse-chat.git
##          - git clone https://github.com/discourse/discourse-ai.git
##          - git clone https://github.com/discourse/discourse-topic-voting.git
##          - git clone https://github.com/discourse/discourse-post-voting.git
##          - git clone https://github.com/discourse/discourse-user-notes.git
##          - git clone https://github.com/discourse/discourse-solved.git
          - git clone https://github.com/discourse/discourse-docs-card-filter.git
          - git clone https://github.com/discourse/discourse-doc-categories.git
##          - git clone https://github.com/discourse/discourse-assign.git
##          - git clone https://github.com/discourse/discourse-templates.git
          - git clone https://github.com/discourse/discourse-saved-searches.git
          - git clone https://github.com/discourse/discourse-tooltips.git
          - git clone https://github.com/discourse/discourse-category-experts.git
          - git clone https://github.com/discourse/discourse-activity-pub.git
          - git clone https://github.com/discourse/discourse-follow.git
          - git clone https://github.com/nathan-nz/discourse-wikified-posts.git
          - git clone https://github.com/discourse/discourse-whos-online.git
          - git clone https://github.com/merefield/discourse-workflow.git
## Remember, this is YAML syntax - you can only have one block with a name
run:
  ## If you want to configure password login for root, uncomment and change:
  ## Use only one of the following lines:
  #- exec: /usr/sbin/usermod -p 'PASSWORD_HASH' root
  - exec: /usr/sbin/usermod -p "$(mkpasswd -m sha-256 'xxxxxxxxxxxxxxx')" root
## for operation behind haproxy load balancer with local nginx on the container host
  - replace:
      filename: /etc/nginx/conf.d/discourse.conf
      to: |
        set_real_ip_from 127.0.0.1/24;
        set_real_ip_from 10.0.0.0/24;
        real_ip_header X-Forwarded-For;
        real_ip_recursive on;
        proxy_set_header Host $http_host;
        proxy_set_header X-Request-Start “t=${msec}”;
        proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
        proxy_set_header X-Forwarded-Proto https; # replaced $thescheme;
        proxy_set_header X-Real-IP $remote_addr;
        types {
  ## If you want to authorized additional users, uncomment and change:
  #- exec: ssh-import-id username
  #- exec: ssh-import-id anotherusername
  - exec: awk -F\# '{print $1;}' ~/.ssh/authorized_keys | awk 'BEGIN { print "Authorized SSH keys for this container:"; } NF>=2 {print $NF;}'
Even when I add a rm -rf block into the ymll:
- rm -rf discourse-chat-integration
- rm -rf discourse-openid-connect
- rm -rf discourse-calendar
- rm -rf discourse-events
- rm -rf discourse-data-explorer
- rm -rf discourse-reactions
- rm -rf discourse-ai
- rm -rf discourse-topic-voting
- rm -rf discourse-post-voting
- rm -rf discourse-user-notes
- rm -rf discourse-solved
- rm -rf discourse-assign
- rm -rf discourse-templates
The bootstrap still fails with
/usr/local/lib/ruby/gems/3.3.0/gems/pups-1.3.0/lib/pups.rb
/usr/local/bin/pups --stdin
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 669 exit 1>
Location of failure: /usr/local/lib/ruby/gems/3.3.0/gems/pups-1.3.0/lib/pups/exec_command.rb:131:in `spawn'
exec failed with the params {"cd"=>"$home", "tag"=>"migrate", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
I would interprete that as an error with the database migration at “bundle exec rake db:migrate”. But what is the root cause here? The discourse2 database already has the vector extension which was required for the (previously already installed) discourse-ai plugin:
postgres=# \c discourse2
psql (15.12 (Ubuntu 15.12-1.pgdg22.04+1), server 13.20 (Ubuntu 13.20-1.pgdg22.04+1))
You are now connected to database "discourse2" as user "postgres".
discourse2=# \dx
                                   List of installed extensions
  Name   | Version |   Schema   |                            Description
hstore   | 1.7     | public     | data type for storing sets of (key, value) pairs
pg_trgm  | 1.5     | public     | text similarity measurement and index searching based on trigrams
plpgsql  | 1.0     | pg_catalog | PL/pgSQL procedural language
unaccent | 1.1     | public     | text search dictionary that removes accents
vector   | 0.8.0   | public     | vector data type and ivfflat and hnsw access methods
(5 rows)
Later on I also see the plugin hints although the “git clone” lines are all commented in the yml:
HINT: The plugin 'discourse-openid-connect' is now bundled with Discourse and should not be included in your container configuration.
Remove the line 'git clone https://github.com/discourse/discourse-openid-connect' from your containers/web_only.yml file, then try again.
For more information, see https://meta.discourse.org/t/373574
To be honest, I am a bit lost now ::sleepy_face: …
what deos free -h return?
root@docker3a:/var/discourse/containers# free -h
total used free shared buff/cache available
Mem: 3.8Gi 2.0Gi 1.1Gi 3.8Mi 969Mi 1.8Gi
probably 4GB of swap
Sorry, my fault, the output was cut off
root@docker3a:~# free -h
gesamt benutzt frei gemns. Puffer/Cache verfügbar
Speicher: 3,8Gi 2,0Gi 1,1Gi 3,8Mi 971Mi 1,8Gi
Swap: 974Mi 0B 974Mi
The VM already has 4 GB of memory. I added 2 GB more and started another ./launcher rebuild web_only^, resulting with the same error. So I doubt we have a space-related build issue here …
Well, I needed 2 GB swap with 8 GB RAM.
I tried again with 8 GB RAM, with the same error result. Note that this is a Kernel-based virtual machine (KVM) on a proxmox host (Features - Proxmox Virtual Environment).
A QEMU/KVM guest requests memory from the host as the guest OS needs it, but it does not return the memory back to the host automatically if the guest OS doesn’t need it anymore. If the host needs memory, the kernel will ask processes to return unused RAM, thus QEMU will try to recover some memory but it depends on guest OS to release it first.
I never had memory issues with the 4 GB RAM and 4 CPU setup, even not with discourse-ai plugin. Bootstrap problems only appeared after this bundling announcement …
Wait is this discourse-openid-connect plugin anywhere in your yml file?
This is an issue migrating, can you scroll up to find what failed to migrate?
Up to now I had discourse-openid-connectin my plugin list. I removed it for the “post-bundling build”. Now I only have these plugins left in the build yml:
## non-bundled plugins
- git clone https://github.com/discourse/docker_manager.git\`
  • git clone https://github.com/discourse/discourse-shared-edits.git
  • git clone https://github.com/discourse/discourse-docs-card-filter.git
  • git clone https://github.com/discourse/discourse-doc-categories.git
  • git clone https://github.com/discourse/discourse-saved-searches.git
  • git clone https://github.com/discourse/discourse-tooltips.git
  • git clone https://github.com/discourse/discourse-category-experts.git
  • git clone https://github.com/discourse/discourse-activity-pub.git
  • git clone https://github.com/discourse/discourse-follow.git
  • git clone ``https://github.com/nathan-nz/discourse-wikified-posts.git
  • git clone https://github.com/discourse/discourse-whos-online.git
  • git clone ``https://github.com/merefield/discourse-workflow.git\`
The build seems to crash at ‘bundle exec rake db:migrate’. But a few lines above I see a
Gem::LoadError: can't activate multipart-post-2.4.0, already activated multipart-post-2.4.1 (Gem::LoadError)
discourse-wikified-posts is already at latest compatible version discourse-workflow is already at latest compatible version docker_manager is already at latest compatible version I,
[2025-07-28T06:34:13.916393 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' rake aborted! Gem::LoadError: can't activate multipart-post-2.4.0, already activated multipart-post-2.4.1 (Gem::LoadError) /var/www/discourse/lib/plugin_gem.rb:25:in `load' /var/www/discourse/lib/plugin/instance.rb:861:in `gem' […]
I have no knowledge about ruby, but maybe this is a package conflict between multipart-post-2.4.0 and multipart-post-2.4.1 ?
Thanks!
Thommie
It is and caused two of my builds to fall over. At least one of CDCKs plugins was using an old version of multipart-post which may now have been updated.
I had to update five plugins of mine to drop back the version of this gem because of this unnecessary additional plugin that I wasn’t using. Looks like I may have to do that exercise all over again for the update.
Very annoying and I’m not a fan of this change at all.
You will have to remove workflow until I update the dependency again.
This is the system working as designed.
When we manage gem dependencies using Gemfile and a Gemfile.lock we have dependbot scanning for updates, we keep up to date using our internal processes.
As a plugin designer you can now depend on the gem dependencies we ship in core.
This means that you should delete multipart-post from you plugins plugin.rb and simply require it from where you are using it.
One less thing for plugin authors to worry about.
Useful feedback, thanks.
@Thomas_Rother I’ve removed the dependency (and another one) from the plugin, give the build another go.
@merefield @sam :smiley: - success!! With the commit 6be7a44 in Roberts plugin GitHub - merefield/discourse-process-manager: A process management plugin for Discourse that moves work through configurable steps with actions, list filters, charts, swim-lane views, and Kanban boards. · GitHub the build is successful. Thanks for analysis and fix!
