حاول إجراء استيراد من Disqus، يقول لم يتم العثور على الفئة
Trying to do the disqus import
discourse@s-app:/var/www/discourse$ RAILS_ENV=production ruby script/import_scripts/disqus.rb --file=/tmp/disqus.xml --dry_run --post-as=system
Category Front page not found
I understand this comes from the section
class ImportScripts::Disqus < ImportScripts::Base
  #CHANGE THESE BEFORE RUNNING THE IMPORTER
  IMPORT_FILE = File.expand_path("/tmp/disqus.xml")
  IMPORT_CATEGORY = "Front page"
Question:
Which category is this referring to and how do I set it?
Importer for reference:
Looks like the disqus importer requires a category name. If you don’t want to import into a specific category just yet, you could change "Front page" by "Uncategorized".
3 إعجابات
Thank you.
Out of curiosity, this refers to a category within discourse, right? And not a category that disqus comments were in.
Yes, a category in Discourse.
إعجاب واحد (1)
Thank you.
Meta: So beautiful that I can see a highlighted line!
تم إغلاق هذا الموضوع تلقائيًا بعد 2396 يومًا. لم يعد يُسمح بالردود الجديدة.
