مرحباً فريق Discourse!
أواجه خطأً عند محاولة تصدير فئة من بيئة التدريج الخاصة بنا إلى بيئة الإنتاج. للسياق، لدينا مجموعة من المواضيع في بيئة التدريج نرغب في نشرها على بيئة الإنتاج، ونسخها ولصقها سيستغرق وقتاً طويلاً.
هذا هو الخطأ الذي أواجهه بعد تشغيل discourse import_category category-export-2022-02-14-042606.json بناءً على هذا البرنامج التعليمي:
Starting import from category-export-2022-02-14-042606.json...
Importing users...
Importing groups...
bundler: failed to load command: script/discourse (script/discourse)
Traceback (most recent call last):
42: from /usr/local/bin/bundle:25:in `<main>'
41: from /usr/local/bin/bundle:25:in `load'
40: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/exe/bundle:36:in `<top (required)>'
39: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/friendly_errors.rb:103:in `with_friendly_errors'
38: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/exe/bundle:48:in `block in <top (required)>'
37: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli.rb:25:in `start'
36: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
35: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli.rb:31:in `dispatch'
34: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
33: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
32: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
31: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli.rb:484:in `exec'
30: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli/exec.rb:23:in `run'
29: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli/exec.rb:58:in `kernel_load'
28: from /usr/local/lib/ruby/gems/2.7.0/gems/bundler-2.3.4/lib/bundler/cli/exec.rb:58:in `load'
27: from script/discourse:290:in `<top (required)>'
26: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/thor-1.2.1/lib/thor/base.rb:485:in `start'
25: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/thor-1.2.1/lib/thor.rb:392:in `dispatch'
24: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/thor-1.2.1/lib/thor/invocation.rb:127:in `invoke_command'
23: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/thor-1.2.1/lib/thor/command.rb:27:in `run'
22: from script/discourse:243:in `import_category'
21: from /var/www/discourse/lib/import_export.rb:15:in `import'
20: from /var/www/discourse/lib/import_export/importer.rb:25:in `perform'
19: from /var/www/discourse/lib/import_export/importer.rb:61:in `import_groups'
18: from /var/www/discourse/lib/import_export/importer.rb:61:in `each'
17: from /var/www/discourse/lib/import_export/importer.rb:65:in `block in import_groups'
16: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/persistence.rb:55:in `create!'
15: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/suppressor.rb:48:in `save!'
14: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/transactions.rb:302:in `save!'
13: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/transactions.rb:350:in `with_transaction_returning_status'
12: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract/database_statements.rb:320:in `transaction'
11: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract/transaction.rb:317:in `within_new_transaction'
10: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `synchronize'
9: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `handle_interrupt'
8: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `block in synchronize'
7: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `handle_interrupt'
6: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/concurrency/load_interlock_aware_monitor.rb:26:in `block (2 levels) in synchronize'
5: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract/transaction.rb:319:in `block in within_new_transaction'
4: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract/database_statements.rb:320:in `block in transaction'
3: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/transactions.rb:354:in `block in with_transaction_returning_status'
2: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/transactions.rb:302:in `block in save!'
1: from /var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/validations.rb:53:in `save!'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/validations.rb:80:in `raise_validation_error': Validation failed: You cannot allow membership requests for a group without any owners. (ActiveRecord::RecordInvalid)
أنا أرغب فقط في تصدير الفئة، لذلك لست متأكداً مما يشكو بشأنه بخصوص المجموعات.
سأكون ممتناً لأي مساعدة!
تحياتي،
تيم
