Intentando recuperar una instalación
Instalé Discourse en una máquina CentOS siguiendo la guía aquí.
Por si sirve de ayuda, también estamos usando NGINX Proxy Manager.
La instalación funcionó durante unas semanas, hasta que tuvimos que reiniciar la máquina. Entonces falló al iniciarse. Aquí está la salida de rebuild:
Launcher is up-to-date
2.0.20230409-0052: Pulling from discourse/base
Digest: sha256:dd75ceb9322f79629f8b0bf78cfb0f79ad6bb366b7ead3e1cd32dcb8712ec46f
Status: Image is up to date for discourse/base:2.0.20230409-0052
docker.io/discourse/base:2.0.20230409-0052
/usr/local/lib/ruby/gems/3.2.0/gems/pups-1.1.1/lib/pups.rb
/usr/local/bin/pups --stdin
I, [2023-04-13T09:55:28.002076 #1]  INFO -- : Reading from stdin
I, [2023-04-13T09:55:28.005509 #1]  INFO -- : > locale-gen $LANG && update-locale
I, [2023-04-13T09:55:28.031953 #1]  INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2023-04-13T09:55:28.032080 #1]  INFO -- : > mkdir -p /shared/postgres_run
I, [2023-04-13T09:55:28.034322 #1]  INFO -- :
I, [2023-04-13T09:55:28.034470 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2023-04-13T09:55:28.036190 #1]  INFO -- :
I, [2023-04-13T09:55:28.036297 #1]  INFO -- : > chmod 775 /shared/postgres_run
I, [2023-04-13T09:55:28.037819 #1]  INFO -- :
I, [2023-04-13T09:55:28.037918 #1]  INFO -- : > rm -fr /var/run/postgresql
I, [2023-04-13T09:55:28.039663 #1]  INFO -- :
I, [2023-04-13T09:55:28.039770 #1]  INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2023-04-13T09:55:28.041327 #1]  INFO -- :
I, [2023-04-13T09:55:28.041457 #1]  INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGS
QL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2023/04/13 09:55:28 socat[19] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file
or directory
I, [2023-04-13T09:55:28.045222 #1]  INFO -- :
I, [2023-04-13T09:55:28.045329 #1]  INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2023-04-13T09:55:28.047498 #1]  INFO -- :
I, [2023-04-13T09:55:28.047590 #1]  INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2023-04-13T09:55:28.049691 #1]  INFO -- :
I, [2023-04-13T09:55:28.049815 #1]  INFO -- : > mkdir -p /shared/postgres_run/13-main.pg_stat_tmp
I, [2023-04-13T09:55:28.051658 #1]  INFO -- :
I, [2023-04-13T09:55:28.051800 #1]  INFO -- : > chown postgres:postgres /shared/postgres_run/13-main.pg_
stat_tmp
I, [2023-04-13T09:55:28.053477 #1]  INFO -- :
I, [2023-04-13T09:55:28.057301 #1]  INFO -- : File > /etc/service/postgres/run  chmod: +x  chown:
I, [2023-04-13T09:55:28.060969 #1]  INFO -- : File > /etc/service/postgres/log/run  chmod: +x  chown:
I, [2023-04-13T09:55:28.064663 #1]  INFO -- : File > /etc/runit/3.d/99-postgres  chmod: +x  chown:
I, [2023-04-13T09:55:28.068319 #1]  INFO -- : File > /root/upgrade_postgres  chmod: +x  chown:
I, [2023-04-13T09:55:28.068510 #1]  INFO -- : > chown -R root /var/lib/postgresql/13/main
I, [2023-04-13T09:55:37.064277 #1]  INFO -- :
I, [2023-04-13T09:55:37.064575 #1]  INFO -- : > [ ! -e /shared/postgres_data ] && install -d -m 0755 -o
I, [2023-04-13T09:55:37.066210 #1]  INFO -- :
I, [2023-04-13T09:55:37.066255 #1]  INFO -- : > chown -R postgres:postgres /shared/postgres_data
I, [2023-04-13T09:55:37.076706 #1]  INFO -- :
I, [2023-04-13T09:55:37.076786 #1]  INFO -- : > chown -R postgres:postgres /var/run/postgresql
I, [2023-04-13T09:55:37.078711 #1]  INFO -- :
I, [2023-04-13T09:55:37.078822 #1]  INFO -- : > /root/upgrade_postgres
I, [2023-04-13T09:55:37.082200 #1]  INFO -- :
I, [2023-04-13T09:55:37.082297 #1]  INFO -- : > rm /root/upgrade_postgres
I, [2023-04-13T09:55:37.083919 #1]  INFO -- :
I, [2023-04-13T09:55:37.084109 #1]  INFO -- : Replacing data_directory = '/var/lib/postgresql/13/main' w
I, [2023-04-13T09:55:37.084484 #1]  INFO -- : Replacing (?-mix:#?listen_addresses *=.*) with listen_addr
I, [2023-04-13T09:55:37.085049 #1]  INFO -- : Replacing (?-mix:#?synchronous_commit *=.*) with synchrono
I, [2023-04-13T09:55:37.085423 #1]  INFO -- : Replacing (?-mix:#?shared_buffers *=.*) with shared_buffer
I, [2023-04-13T09:55:37.085857 #1]  INFO -- : Replacing (?-mix:#?work_mem *=.*) with work_mem = $db_work
I, [2023-04-13T09:55:37.086303 #1]  INFO -- : Replacing (?-mix:#?default_text_search_config *=.*) with d
I, [2023-04-13T09:55:37.086614 #1]  INFO -- : > install -d -m 0755 -o postgres -g postgres /shared/postg
I, [2023-04-13T09:55:37.089011 #1]  INFO -- :
I, [2023-04-13T09:55:37.089245 #1]  INFO -- : Replacing (?-mix:#?checkpoint_segments *=.*) with checkpoi
I, [2023-04-13T09:55:37.089516 #1]  INFO -- : Replacing (?-mix:#?logging_collector *=.*) with logging_co
I, [2023-04-13T09:55:37.089887 #1]  INFO -- : Replacing (?-mix:#?log_min_duration_statement *=.*) with l
I, [2023-04-13T09:55:37.090322 #1]  INFO -- : Replacing (?-mix:^#local +replication +postgres +peer$) wi
I, [2023-04-13T09:55:37.090509 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*127.*$) with host all al
I, [2023-04-13T09:55:37.090946 #1]  INFO -- : Replacing (?-mix:^host.*all.*all.*::1\/128.*$) with host a
I, [2023-04-13T09:55:37.091279 #1]  INFO -- : > HOME=/var/lib/postgresql USER=postgres exec chpst -u pos
I, [2023-04-13T09:55:37.092562 #1]  INFO -- : > sleep 5
2023-04-13 09:55:37.239 UTC [42] LOG:  starting PostgreSQL 13.10 (Debian 13.10-1.pgdg110+1) on x86_64-pc
2023-04-13 09:55:37.240 UTC [42] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2023-04-13 09:55:37.240 UTC [42] LOG:  listening on IPv6 address "::", port 5432
2023-04-13 09:55:37.287 UTC [42] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2023-04-13 09:55:37.338 UTC [45] LOG:  database system was interrupted; last known up at 2023-04-13 08:3
2023-04-13 09:55:37.795 UTC [45] LOG:  invalid resource manager ID in primary checkpoint record
2023-04-13 09:55:37.795 UTC [45] PANIC:  could not locate a valid checkpoint record
2023-04-13 09:55:38.256 UTC [42] LOG:  startup process (PID 45) was terminated by signal 6: Aborted
2023-04-13 09:55:38.256 UTC [42] LOG:  aborting startup due to startup process failure
2023-04-13 09:55:38.283 UTC [42] LOG:  database system is shut down
I, [2023-04-13T09:55:42.094474 #1]  INFO -- :
I, [2023-04-13T09:55:42.094602 #1]  INFO -- : > su postgres -c 'createdb discourse' || true
createdb: error: could not connect to database template1: connection to server on socket "/var/run/postg
        Is the server running locally and accepting connections on that socket?
I, [2023-04-13T09:55:42.130700 #1]  INFO -- :
I, [2023-04-13T09:55:42.130828 #1]  INFO -- : > su postgres -c 'psql discourse -c "create user discourse
psql: error: connection to server on socket "/var/run/postgresql/.s.PGSQL.5432" failed: No such file or directory
I, [2023-04-13T09:55:42.166116 #1]  INFO -- :
I, [2023-04-13T09:55:42.166242 #1]  INFO -- : > su postgres -c 'psql discourse -c "grant all privileges on database discourse to discourse;"' || true
I, [2023-04-13T09:55:42.201461 #1]  INFO -- :
I, [2023-04-13T09:55:42.201617 #1]  INFO -- : > su postgres -c 'psql discourse -c "alter schema public owner to discourse;"'
I, [2023-04-13T09:55:42.236768 #1]  INFO -- :
I, [2023-04-13T09:55:42.236996 #1]  INFO -- : Terminating async processes
FAILED
Pups::ExecError: su postgres -c 'psql discourse -c "alter schema public owner to discourse;"' failed with return #<Process::Status: pid 55 exit 2>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.1.1/lib/pups/exec_command.rb:117:in `spawn'
exec failed with the params "su postgres -c 'psql $db_name -c \\\"alter schema public owner to $db_user;\\\"'"
bootstrap failed with exit code 2
cd04fbb38f1ef61e418d680b969c2c056439e3b1dbfe64608524a8d3361cd91c
discourse-doctor no encuentra la aplicación docker en ejecución:
==================== SERIOUS PROBLEM!!!! ====================
app not running!
Attempting to rebuild
Y intenta reconstruir, por lo que básicamente termina con el mismo registro anterior.
¡Gracias de antemano!
Creo que tu base de datos está corrupta. En mi opinión, lo mejor sería restaurar desde una copia de seguridad. Creo que Discourse puede hacer copias de seguridad por defecto. Busca en discourse/shared/app/backups o algo así.
Si no tienes una copia de seguridad de Discourse, entonces esto se convierte más en un tema de soporte de PostgreSQL que de Discourse. Podría intentar ayudar, supongo, pero no soy un experto.
Puede que tengas que usar esto:
A mí también me suena a eso. Espero que puedas encontrar una solución @Norike … mientras tanto, esto me parece bastante preocupante: creo que un reinicio iniciado por software debería dejar la base de datos en un estado limpio. ¿Fue un reinicio forzado, es decir, un ciclo de energía?
Me pregunto si marca alguna diferencia en el sistema de archivos en el que está almacenada tu base de datos. ¿Qué te dice df -T?
¡Gracias!
De hecho, encontré algunas copias de seguridad en la carpeta /var/discourse/shared/standalone/backups/default, lo que parece prometedor.
Sin embargo, según la guía Restaurar una copia de seguridad desde la línea de comandos, el contenedor debe estar en ejecución para importar la base de datos, pero el comando ./launcher enter app falla:
Se detectó la arquitectura x86_64.
ADVERTENCIA: el archivo containers/app.yml es legible por todos. Puede proteger este archivo ejecutando: chmod o-rwx containers/app.yml
Respuesta de error del demonio: No existe tal contenedor: app
Supongo que debería empezar con una instalación limpia. ¿Hay alguna guía para limpiar y empezar de nuevo? ¿Sería correcto lo siguiente?
  • Copiar las copias de seguridad de la carpeta /var/discourse/shared/standalone/backups/default a una ubicación diferente fuera de la carpeta /var/discourse
  • Eliminar la carpeta /var/discourse
  • Instalar Discourse desde cero siguiendo la guía Instalar en la nube para tener una nueva instancia en funcionamiento.
  • Restaurar la copia de seguridad con la GUI o con la guía de línea de comandos anterior.
Fue un reinicio por software después de aplicar algunas actualizaciones.
Esto:
Filesystem          Type     1K-blocks     Used Available Use% Mounted on
devtmpfs            devtmpfs      4096        0      4096   0% /dev
tmpfs               tmpfs      3869940        0   3869940   0% /dev/shm
tmpfs               tmpfs      1547980    17600   1530380   2% /run
/dev/mapper/cs-root xfs       73364480 16750976  56613504  23% /
/dev/sda2           xfs        1038336   395812    642524  39% /boot
/dev/mapper/cs-home xfs      893122476 10838052 882284424   2% /home
/dev/sda1           vfat        613160     7644    605516   2% /boot/efi
overlay             overlay   73364480 16750976  56613504  23% /var/lib/docker/overlay2/a9c2622d4167f08ff4697a4c49febf55a7e460e087c41c05e6c1bbd321b13f62/merged
overlay             overlay   73364480 16750976  56613504  23% /var/lib/docker/overlay2/765273939fa75096c994588ba9c9bac6b5a9b909a60a962169b83f7c8a213b7f/merged
tmpfs               tmpfs       773988        4    773984   1% /run/user/1000
Gracias. No estoy familiarizado con XFS, pero una búsqueda rápida sugiere que debería ser seguro de usar. Quizás xfs_info / sea útilmente informativo.
ok, entonces copia todo este directorio a algún lugar para guardarlo:
de esa manera puedes intentar restaurar desde copias de seguridad o incluso intentar reparar la base de datos corrupta si es necesario.
luego elimina tus contenedores docker, haz un docker image prune -a, elimina /var/discourse e instala discourse de nuevo. luego copia el archivo de copia de seguridad más reciente en su lugar e intenta restaurar.
¡Eso lo restauró. ¡Gracias!
