Erreur de connexion et d'inscription sur Twitter
I have gone through all the steps provided to add login via twitter but after finishing all steps when i tried login it is giving me this error
# Oops
The software powering this discussion forum encountered an unexpected problem. We apologize for the inconvenience.
Detailed information about the error was logged, and an automatic notification generated. We’ll take a look at it.
No further action is necessary. However, if the error condition persists, you can provide additional detail, including steps to reproduce the error, by posting a discussion topic in the site’s feedback category.
All other logins are working fine but only twitter is giving me this error.
My forum link is https://forum.cyberthana.com
I’d suggest to look into your twitter application first to see if it has permissions sorted properly.
Then I’d cross check with all the tokens and secrets for possible mismatch.
This is my permission setting for my twitter app.
Try it with read & write then test again!
Also, an interesting place to look at would be https://ask.cyberthana.com/logs and /admin/logs to know exactly what is failing.
Also, Your forum seems to be configured over SSL so one thing to check will be force_https in your admin panel and confirming if you have set up https links in the twitter application.
My twitter configuration is as follows and it works fine:
Settings to request email and App permission is Read only.
refer this:
Thanku,
I have edited callback URL from http://ask.cyberthana.com/auth/twitter/callback to https://ask.cyberthana.com/auth/twitter/callback
And now its working fine.
