I pulled down the DiscourseMobile from github. According to the github page, you run npm init and then react-native run-android. That didn’t work, but it did indicate that npm install is needed first. I did that and it downloaded a bunch of stuff. Then, I tried importing into Android Studio and installed on my device, but it failed with an error about BundledBatch. I click on “RELOAD” on the bottom and get another error about development server.
How do I get it to work from a build?
Attached screenshots of the errors.
