I repeatedly get this error popup whenever I try to click “submit” while creating a new persona, even though everything is correctly set up and my other AI bots work fine. There’s also nothing coming up in the error logs. My instance is fully up-to-date.
Can you have a look in console to see if there is more detail on the error?
Cc @Roman
I entered production.log but didn’t notice anything logged there when I just recreated this error.
Oh I can repro this, just enter test, test, test and I get that error
Also clicking enable clears everything
We will have a look asap
Thanks, that will be fixed in: FIX: do not error when tools are empty by jjaffeux · Pull Request #1218 · discourse/discourse-ai · GitHub
In the meantime, if you add a tool and remove it, you should be able to save your form.
I can confirm everything has been fixed from my side. Once again y’all have saved the day
This topic was automatically closed 3 days after the last reply. New replies are no longer allowed.
