RuntimeError (Utente già esistente)
app/controllers/application_controller.rb:422:in `block in with_resolved_locale'
app/controllers/application_controller.rb:422:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:64:in `call'
lib/middleware/anonymous_cache.rb:393:in `call'
lib/middleware/csp_script_nonce_injector.rb:12:in `call'
config/initializers/008-rack-cors.rb:14:in `call'
config/initializers/100-quiet_logger.rb:20:in `call'
config/initializers/100-silence_logger.rb:29:in `call'
lib/middleware/enforce_hostname.rb:24:in `call'
lib/middleware/request_tracker.rb:289:in `call'
Backtrace
plugins/discourse-ai/app/models/ai_persona.rb:186:in `create_user!'
plugins/discourse-ai/app/controllers/discourse_ai/admin/ai_personas_controller.rb:45:in `create_user'
actionpack (7.0.8.4) lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack (7.0.8.4) lib/abstract_controller/base.rb:215:in `process_action'
actionpack (7.0.8.4) lib/action_controller/metal/rendering.rb:165:in `process_action'
actionpack (7.0.8.4) lib/abstract_controller/callbacks.rb:234:in `block in process_action'
activesupport (7.0.8.4) lib/active_support/callbacks.rb:118:in `block in run_callbacks'
i18n (1.14.5) lib/i18n.rb:351:in `with_locale'
activesupport (7.0.8.4) lib/active_support/callbacks.rb:127:in `block in run_callbacks'
activesupport (7.0.8.4) lib/active_support/callbacks.rb:138:in `run_callbacks'
actionpack (7.0.8.4) lib/abstract_controller/callbacks.rb:233:in `process_action'
actionpack (7.0.8.4) lib/action_controller/metal/rescue.rb:23:in `process_action'
actionpack (7.0.8.4) lib/action_controller/metal/instrumentation.rb:67:in `block in process_action'
activesupport (7.0.8.4) lib/active_support/notifications.rb:206:in `block in instrument'
activesupport (7.0.8.4) lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport (7.0.8.4) lib/active_support/notifications.rb:206:in `instrument'
actionpack (7.0.8.4) lib/action_controller/metal/instrumentation.rb:66:in `process_action'
actionpack (7.0.8.4) lib/action_controller/metal/params_wrapper.rb:259:in `process_action'
activerecord (7.0.8.4) lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack (7.0.8.4) lib/abstract_controller/base.rb:151:in `process'
actionview (7.0.8.4) lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler (3.3.1) lib/mini_profiler/profiling_methods.rb:89:in `block in profile_method'
actionpack (7.0.8.4) lib/action_controller/metal.rb:188:in `dispatch'
actionpack (7.0.8.4) lib/action_controller/metal.rb:251:in `dispatch'
actionpack (7.0.8.4) lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
actionpack (7.0.8.4) lib/action_dispatch/routing/route_set.rb:32:in `serve'
actionpack (7.0.8.4) lib/action_dispatch/routing/mapper.rb:18:in `block in <class:Constraints>'
actionpack (7.0.8.4) lib/action_dispatch/routing/mapper.rb:48:in `serve'
actionpack (7.0.8.4) lib/action_dispatch/journey/router.rb:50:in `block in serve'
actionpack (7.0.8.4) lib/action_dispatch/journey/router.rb:32:in `each'
actionpack (7.0.8.4) lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack (7.0.8.4) lib/action_dispatch/routing/route_set.rb:852:in `call'
rack (2.2.9) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.9) lib/rack/conditional_get.rb:40:in `call'
rack (2.2.9) lib/rack/head.rb:12:in `call'
actionpack (7.0.8.4) lib/action_dispatch/http/permissions_policy.rb:38:in `call'
rack (2.2.9) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.9) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (7.0.8.4) lib/action_dispatch/middleware/cookies.rb:704:in `call'
actionpack (7.0.8.4) lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
activesupport (7.0.8.4) lib/active_support/callbacks.rb:99:in `run_callbacks'
actionpack (7.0.8.4) lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack (7.0.8.4) lib/action_dispatch/middleware/debug_exceptions.rb:28:in `call'
actionpack (7.0.8.4) lib/action_dispatch/middleware/show_exceptions.rb:29:in `call'
logster (2.19.1) lib/logster/middleware/reporter.rb:40:in `call'
railties (7.0.8.4) lib/rails/rack/logger.rb:40:in `call_app'
railties (7.0.8.4) lib/rails/rack/logger.rb:27:in `call'
actionpack (7.0.8.4) lib/action_dispatch/middleware/remote_ip.rb:93:in `call'
actionpack (7.0.8.4) lib/action_dispatch/middleware/request_id.rb:26:in `call'
rack (2.2.9) lib/rack/method_override.rb:24:in `call'
actionpack (7.0.8.4) lib/action_dispatch/middleware/executor.rb:14:in `call'
rack (2.2.9) lib/rack/sendfile.rb:110:in `call'
actionpack (7.0.8.4) lib/action_dispatch/middleware/host_authorization.rb:131:in `call'
rack-mini-profiler (3.3.1) lib/mini_profiler.rb:191:in `call'
message_bus (4.3.8) lib/message_bus/rack/middleware.rb:60:in `call'
railties (7.0.8.4) lib/rails/engine.rb:530:in `call'
railties (7.0.8.4) lib/rails/railtie.rb:226:in `public_send'
railties (7.0.8.4) lib/rails/railtie.rb:226:in `method_missing'
rack (2.2.9) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.9) lib/rack/urlmap.rb:58:in `each'
rack (2.2.9) lib/rack/urlmap.rb:58:in `call'
unicorn (6.1.0) lib/unicorn/http_server.rb:634:in `process_client'
unicorn (6.1.0) lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn (6.1.0) lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn (6.1.0) lib/unicorn/http_server.rb:143:in `start'
unicorn (6.1.0) bin/unicorn:128:in `<top (required)>'
vendor/bundle/ruby/3.2.0/bin/unicorn:25:in `load'
vendor/bundle/ruby/3.2.0/bin/unicorn:25:in `<main>'
Ricevo questo errore anche se l’account non esiste.
- Viene creato un utente errato che non corrisponde alla mia persona.
- Ad esempio, se provo a creare un account Setup Helper AI, crea un account GitHub AI.
- Ho provato a eliminare e riprovare più volte, ma non ha funzionato.
- In alcuni casi, la creazione non è andata a buon fine, restituendo un errore interno mentre ripetevo più volte l’eliminazione e la creazione.
Spero che questo errore venga risolto presto.
