Não é possível personalizar o texto do botão "Accept Invite"
Hi @techAPJ
Is the language of the “Accept Invite” button customizable?
I can’t find it in Settings > Customize > Text Content > Search…
Yes, search for ‘Accept Invitation’ or ‘accept_invite’.
6 curtidas
Huh… I guess I was confused because the default text for js.invites.accept_invite doesn’t match what we see on the button.
Note: Invitation vs Invite
Here’s the result for accept_invite (we haven’t customized it)
And here’s what we see for the button:
… and when I change the value in accept_invite it doesn’t change what we see in the button.
We’re using the discourse-invite-tokens plugin and this is the Accept Invite page for the issue discussed on another topic about the “helpful” email spam checkers triggering the token.
2 curtidas
That explains the problem. The discourse-invite-tokens plugin is missing a translation for the accept_invite key. We will get that added right away. When that has been done, you’ll be able to customize the “Accept Invite” button text.
6 curtidas
Wonderful, thank you
3 curtidas
I just checked in on this and it looks like you still need to add the missing translation. Do you know when that will be done?
1 curtida
Sorry for the delay. The fix should be deployed within the next 15 minutes.
5 curtidas
It’s working, thank you!
Note (for anyone trying to customize this): There are now two places to customize. One for invites via the discourse-invite-tokens plugin and another for normal invites.
invite.accept_invite is for the discourse-invite-tokens plugin.
js.invites.accept_invite is for normal invites
3 curtidas
This topic was automatically closed 24 hours after the last reply. New replies are no longer allowed.
