לא ניתן לבנות מחדש עקב ערכות נושא: עדכון נכשל בערכת נושא ללא שינוי
סיכום מבוסס בינה מלאכותית
The user mentalstring is unable to update their Discourse instance from 2.8.10 to 2.8.11 due to a failure in the themes:update task. The error, undefined method scheme’ for nil:NilClass`, occurs when updating a remote theme hosted on a private GitHub repository. The issue persists both when running the task manually and via the web interface, where it results in a 500 error. The theme itself has not been modified recently and is relatively simple, suggesting a potential change in Discourse’s theme handling logic.
I’m trying to update to the latest stable (from 2.8.10 to 2.8.11) and it’s aborting while calling themes:update. I tried to run the themes:update task manually and the error is the same:
# rake themes:update
Checking 'xyz (darker)' for 'default'... Failed to update 'xyz (darker)': undefined method `scheme' for nil:NilClass
rake aborted!
NoMethodError: undefined method `scheme' for nil:NilClass
/var/www/discourse/lib/theme_store/git_importer.rb:129:in `clone_http!'
/var/www/discourse/lib/theme_store/git_importer.rb:94:in `clone!'
/var/www/discourse/lib/theme_store/git_importer.rb:19:in `import!'
/var/www/discourse/app/models/remote_theme.rb:126:in `update_remote_version'
/var/www/discourse/lib/tasks/themes.rake:62:in `block in update_themes'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.6.1/lib/active_record/relation/batches.rb:71:in `block (2 levels) in find_each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.6.1/lib/active_record/relation/batches.rb:71:in `each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.6.1/lib/active_record/relation/batches.rb:71:in `block in find_each'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.6.1/lib/active_record/relation/batches.rb:138:in `block in find_in_batches'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.6.1/lib/active_record/relation/batches.rb:245:in `block in in_batches'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.6.1/lib/active_record/relation/batches.rb:229:in `loop'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.6.1/lib/active_record/relation/batches.rb:229:in `in_batches'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.6.1/lib/active_record/relation/batches.rb:137:in `find_in_batches'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.6.1/lib/active_record/relation/batches.rb:70:in `find_each'
/var/www/discourse/lib/tasks/themes.rake:56:in `update_themes'
/var/www/discourse/lib/tasks/themes.rake:87:in `block (2 levels) in <main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rails_multisite-4.0.0/lib/rails_multisite/connection_management.rb:80:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rails_multisite-4.0.0/lib/rails_multisite/connection_management.rb:90:in `each_connection'
/var/www/discourse/lib/tasks/themes.rake:86:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bundler-2.3.22/lib/bundler/cli/exec.rb:58:in `load'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bundler-2.3.22/lib/bundler/cli/exec.rb:58:in `kernel_load'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bundler-2.3.22/lib/bundler/cli/exec.rb:23:in `run'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bundler-2.3.22/lib/bundler/cli.rb:486:in `exec'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bundler-2.3.22/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bundler-2.3.22/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bundler-2.3.22/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bundler-2.3.22/lib/bundler/cli.rb:31:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bundler-2.3.22/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bundler-2.3.22/lib/bundler/cli.rb:25:in `start'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bundler-2.3.22/exe/bundle:48:in `block in <top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bundler-2.3.22/lib/bundler/friendly_errors.rb:120:in `with_friendly_errors'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/bundler-2.3.22/exe/bundle:36:in `<top (required)>'
Tasks: TOP => themes:update
The theme in question has not been changed (for over a year) and is in fact pretty basic — only changes some colors and adds a single css rule, so something seems to have changed in discourse. Not sure if relevant, but the theme is remote (github private repos).
After this I noticed that if I try to update the theme from the web interface, I get a 500 error with similar error:
Started PUT "/admin/themes/48" for x.x.x.x at 2022-11-14 17:44:14 +0000
Processing by Admin::ThemesController#update as */*
  Parameters: {"theme"=>{"remote_check"=>true}, "id"=>"48"}
Completed 500 Internal Server Error in 1904ms (ActiveRecord: 0.0ms | Allocations: 24475)
NoMethodError (undefined method `scheme' for nil:NilClass)
app/controllers/admin/themes_controller.rb:207:in `update'
app/controllers/application_controller.rb:387:in `block in with_resolved_locale'
app/controllers/application_controller.rb:387:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:71:in `call'
lib/middleware/anonymous_cache.rb:361:in `call'
config/initializers/100-quiet_logger.rb:23:in `call'
config/initializers/100-silence_logger.rb:31:in `call'
lib/middleware/enforce_hostname.rb:23:in `call'
lib/middleware/request_tracker.rb:198:in `call'
Any idea what I should be looking into? Can share the theme files if it helps.
EDIT TO ADD: Changing the repo to public stopped the error, so something seems to have changed with the handling of private repos using auth tokens. However, oddly, changing the repo back to private didn’t bring the error back on rebuild… Plus, there’s two remote themes with the same setup (in private repo) and only one of them failed.
