Hello,
I have tried to reinstall Discourse from scratch. And installation fails, i have an error to verify first certificate i have never had before. And then installation fails …
Any idea what could be the problem ?
> warning Resolution field "unset-value@2.0.1" is incompatible with requested version "unset-value@^1.0.0"
**error Error: unable to verify the first certificate**
at TLSSocket.onConnectSecure (node:_tls_wrap:1659:34)
at TLSSocket.emit (node:events:517:28)
at TLSSocket._finishInit (node:_tls_wrap:1070:8)
at ssl.onhandshakedone (node:_tls_wrap:856:12)
I, [2024-06-05T17:24:31.603840 #1] INFO -- : yarn install v1.22.22
[1/5] Validating package.json...
[2/5] Resolving packages...
[3/5] Fetching packages...
info Visit https://yarnpkg.com/en/docs/cli/install for documentation about this command.
I, [2024-06-05T17:24:31.604648 #1] INFO -- : Terminating async processes
I, [2024-06-05T17:24:31.604696 #1] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 36
2024-06-05 17:24:31.605 UTC [36] LOG: received fast shutdown request
I, [2024-06-05T17:24:31.605048 #1] INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 98
98:signal-handler (1717608271) Received SIGTERM scheduling shutdown...
2024-06-05 17:24:31.608 UTC [36] LOG: aborting any active transactions
2024-06-05 17:24:31.612 UTC [36] LOG: background worker "logical replication launcher" (PID 51) exited with exit code 1
2024-06-05 17:24:31.612 UTC [46] LOG: shutting down
2024-06-05 17:24:31.628 UTC [36] LOG: database system is shut down
98:M 05 Jun 2024 17:24:31.702 # User requested shutdown...
98:M 05 Jun 2024 17:24:31.702 * Saving the final RDB snapshot before exiting.
98:M 05 Jun 2024 17:24:31.703 * DB saved on disk
98:M 05 Jun 2024 17:24:31.703 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'yarn install --frozen-lockfile && yarn cache clean' failed with return #<Process::Status: pid 401 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"yarn", "cmd"=>["if [ \"$version\" != \"tests-passed\" ]; then\n rm -rf app/assets/javascripts/node_modules\nfi", "su discourse -c 'yarn install --frozen-lockfile && yarn cache clean'"]}
b8046f40c39734eb8318b7f868a92127b963e33f1970d43bb122c1c650107e7a
