データエクスプローラーでグループを選択できません
I’m not able to use the new feature to allow certain groups to access queries. What am I missing?
Discourse 2.4.0.beta5 Release Notes
discourse-data-explorer
  • Allow groups to access queries
I have this box in Data Explorer:
But it doesn’t work- for example if I type “moderators” (with no quotes), it doesn’t search or auto-complete, and if I save the query and come back to it, the box is empty again, and moderators do not have access to the query.
I’ve tried other groups as well- the problem is not specific to moderators.
I don’t see any related settings- only the setting is to enable Data Explorer.
「いいね!」 1
@markvanlan any ideas about :arrow_double_up:
「いいね!」 1
If you’re self hosted, Did you upgrade both discourse and the data explorer plugin?
「いいね!」 1
I am not able to reproduce this locally, and group selection is working here on meta.
Even if Discourse was not updated when the data-explorer plugin was, the groups should still be able to be added.
「いいね!」 4
I did ./launcher rebuild app. I saw it pull the plugins, watching the console.
「いいね!」 1
Are you on the stable branch?
「いいね!」 2
I’m using 2.4.0.beta6.
Any non official plugins installed?
Yes, but realistically this isn’t a high enough priority to start eliminating plugins and css customisations, if it’s working for everyone else.
You can first try by using safe-mode. You could use this mode of safe-mode:
http://www.example.com/?safe_mode=no_custom%2Conly_official
If you can still repo with this, then it’s not from a non official plugin, and this test won’t impact your users.
「いいね!」 2
Nice. But I can still repo. Found this in the console, both with Chrome and Firefox. Will try to drill down further tomorrow, but I’m a bit out of my depth here.
「いいね!」 1
seems like select-kit related I will have a look.
「いいね!」 1
That should fix it (you will need to pull the last version of the plugin):
For some reason group_ids were retrieved in 3 formats : nil, [], ""… and select-kit had troubles looping over ""
The important fix is in plugin.rb, but I also tried to make it more resilient at other parts of the code.
@markvanlan I imagine some version of this code were buggy at some point and created some corrupted data like this? Feel free to dig more if you think there’s something to change/migrate.
I also made a few other commits while I was at it:
「いいね!」 5
This topic was automatically closed after 33 hours. New replies are no longer allowed.
