It will be cool if can we be unassigned on Solved. Since we do left open topics for while after solving
Also please consider multiple assignments, so one topic can be assigned to multiple users.
Open to adding that as an option for “auto unassign on solved” however “auto close on solved” sort of solves this anyway.
I wonder, why do you not split these kind of topics that need multi-assign?
Hi,
we would also be interested in a “Auto unassign on solved topics” solution
This is only partially true. Solved status is a less strict way to conclude than closing the topic. For example if a staff member considers topic solved, but the user doesn’t, they may continue the discussion or unmark as solved. Closing a topic doesn’t allow such flexibility.
