What subdomain should I use for setting up Mailgun?
My discourse installation will be hosted at members.example.com
I started configuring the Mailgun domain records for members.example.com but then came across this article which says to use discourse.example.com but it’s not clear if that was just for the purposes of that example or if this is a rule of the software.
The install guide does not seem to provide any guidance on this.
Thank you
