In a support discussion titled ‘Unlisted topic is visible in notification popup if a category is watched?’, user dax reports that an unlisted topic posted in a private category appeared in the notifications of users who had that category marked as ‘watched’, despite expecting unlisted topics to be visible only to admins/moderators. pfaffman explains that notifications are triggered at the moment of posting — before unlisting — and suggests posting in a private category, unlisting, then moving it. jomaxro clarifies that to avoid notifications entirely, users should toggle ‘Unlisted’ before posting, showing a screenshot of the UI toggle. dax questions the utility of unlisting if watched-category users still see it, suggesting the toggle should be available during topic creation. jomaxro confirms the toggle was added precisely for this purpose and links to the original feature request. Confusion arises when dax conflates ‘Unlisted’ with ‘Whisper’; jomaxro clarifies they are distinct: Unlisted topics are link-only visible, while Whispers are staff-only posts. dax asks if there’s a setting to make Whispers visible to all — jomaxro confirms no such setting exists. dax acknowledges the clarification, thanks the contributors, and requests closure. The topic was moved to Product Support.
I posted a new topic in our private category and I made it immediately unlisted.
After a few hours I see the topic received one like by a team-member and then a reply from another team-member.
The unlisted topics should not be visible only to administrators and moderators?
I think the problem here is that those members have the category as “watched” on their profiles.
Infact they “see” this unlisted topic when they opened the notifications tab clicking on their avatars.
I asked to another team-member to check his notifications and he hasn’t received it.
I checked his profile settings and I see he has no categories “watched”.
If they are watching the category, then they got a notification immediately when you posted the topic, before you unlisted it.
If you want it to be in some category that people might be watching, but have it not show up in their notifications, it might work to post it in a private category, unlist it, then move it to that category.
Just to double check, you posted it, and only after it was posted you used the admin wrench to make it unlisted? That short moment will allow for the notification.
If you want to avoid the notifications, make the topic unlisted before you post it:
But what is the sense of having a similar function if the topic is equally visible for users that watch a category?
I mean, I know that we can unlist a topic already published for a zillion of reasons but I also believe that this particular function should be implemented in some way when we create new topics.
I’m a bit confused here. If I recall correctly, the toggle I shared above was added to address your exact complaint. It allows you to create a topic that is unlisted when it is created, thus preventing notifications. It’s not a workaround…
Whisper and Unlisted are completely different functions. Unlisted applies to topics, where whisper applies to posts. An unlisted topic can only be seen by those with a direct link. A whisper is a post that can only be seen by site staff.
