Unneeded search refresh in text overriding screen
  1. Search for a translation key
  2. Ctrl+A to select the whole search term
  3. Extra search will be carried again - but no needed for it as the text has not been changed.
The same issue whatever keys I press in the search box that do not change the text. It would be better to check if the text has changed after a key press to decided whether a new search should be carried again.
Here’s a fix:
