Aankomende wijzigingen in de onderwerplijst - hoe thema's en plugins voor te bereiden
Sorry to eat into your weekend David, yes, just saw the API, thanks
Hi, I’ve tried to use value transformer for ā€œtopic-list-columnsā€ like this:
export default {
    initialize(container) {
        const router = container.lookup("service:router");
        withPluginApi("1.39.0", (api) => {
            api.registerValueTransformer(
                "topic-list-columns",
                ({ value: columns }) => {
                    if (ASSIGN_LIST_ROUTES.includes(router.currentRouteName)) {
                        columns.add("posters-recent", {
                            header: AssignHeaderCell,
                            item: AssignCell,
                            after: "posters",
                    return columns;
The goal is to insert new column item and header after ā€œpostersā€ column, it works for the item, but the header still not in the right place, it was placed after ā€œactivityā€ column.
Is there something missing in my code? and is there any documentation that explain how to do this correctly?
There is a new guide:
However, it may not be very useful in this case.
@NateDhaliwal thanks for the info, i will check it.
I think the code should look like:
columns.add(
  "posters-recent",
  { header: AssignHeaderCell, item: AssignCell }
  { after: "posters"}
And you might need to specify a before:
{after: "posters", before: "replies"}
@Arkshine thanks a lot, your code works !!! awesome :+1:
We’ve now enabled the warning banner for these deprecations, so community admins will be notified about any themes or plugins which still need to be updated.
We’ve also published a reference guide with signposts to all the different ways you can customize the new topic list:
I’ve added a link to that from the OP.
David, not sure if you prefer this Topic or the other, but here goes:
My new compliant (I think) component is failing when Enable Glimmer Topic List is set to Auto …
It suggests the new API is not being activated on Auto … is there something I need to do to sign-post the Theme Component so Discourse uses the new Glimmer API when on Auto?
I’ve noticed the warning here:
But it’s still not messing anything up despite the date you provided above has passed and I’m on the latest build…?
Things are delayed a little bit, but we hope to finish dropping the old code in the next 1-2 weeks
So would that completely break themes who aren’t up to date yet? Should we avoid updating? or is there anything we can do simply if we fork the theme?
It will prevent their customizations to the topic-list from being applied, yes.
I wouldn’t recommend that. Discourse core updates often include security fixes, and your community may be vulnerable if you stop updating.
Sounds like you got it figured out in the other topic :chefs_kiss:
The legacy topic-list and ā€œraw handlebarsā€ systems have now been removed from Discourse core. Thanks to everyone who helped to update plugins and themes for this change! :rocket:
That’s fantastic! Congrats to the CDCK team who worked on this. :partying_face:
Also thanks to you and the team for being very receptive to feature requests and so thoughtful on the design of the new API :heart_eyes:
I had feared we would lose some capabilities. But what actually happened was we got many more whilst at the same time being significantly easier to work with! :rocket:
Regarding raw templates, do I understand correctly that using components in the template with the autocomplete function is no longer possible (e.g., emoji)?
this.textManipulation.autocomplete({
      template: renderEmojiAutocomplete,
It seems that you can only return HTML now.
I think you said autocomplete will be reworked at some point, but it’s likely not anytime soon.
Do you see a workaround here? (Trying to fix Emoji Fluff TC)
Unfortunately we didn’t get a proper deprecation message in place for autocomplete, sorry! But there is a path forwards - check out: Autocomplete still using Raw Templates - #4 by david
