アップグレード失敗: ERROR: relation "idx_regular_post_search_data" は既に存在します
I upgated the app yesterday and just wanted to upgrade the newest 27 comments. I did so via the docker manager in the admin backend. However, the upgrade stalled at some point. After 30 minutes I went into the console and tried via:
./launcher rebuild app
Now I got this and don’t know what to do now:
discourse-adplugin is already at latest compatible version
discourse-akismet is already at latest compatible version
discourse-solved is already at latest compatible version
I, [2020-08-18T14:41:23.748557 #1]  INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
2020-08-18 14:41:26.896 UTC [3021] discourse@discourse ERROR:  relation "idx_regular_post_search_data" already exists
2020-08-18 14:41:26.896 UTC [3021] discourse@discourse STATEMENT:  CREATE INDEX CONCURRENTLY idx_regular_post_search_data ON post_search_data USING GIN(search_data) WHERE NOT private_message
rake aborted!
StandardError: An error has occurred, all later migrations canceled:
PG::DuplicateTable: ERROR:  relation "idx_regular_post_search_data" already exists
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-2.0.4/lib/patches/db/pg.rb:110:in `exec'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rack-mini-profiler-2.0.4/lib/patches/db/pg.rb:110:in `async_exec'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/connection_adapters/postgresql/database_statements.rb:92:in `block (2 levels) in execute'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.2/lib/active_support/dependencies/interlock.rb:48:in `block in permit_concurrent_loads'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.2/lib/active_support/concurrency/share_lock.rb:187:in `yield_shares'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.2/lib/active_support/dependencies/interlock.rb:47:in `permit_concurrent_loads'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/connection_adapters/postgresql/database_statements.rb:91:in `block in execute'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/connection_adapters/abstract_adapter.rb:722:in `block (2 levels) in log'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.2/lib/active_support/concurrency/load_interlock_aware_monitor.rb:26:in `block (2 levels) in synchronize'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.2/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `handle_interrupt'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.2/lib/active_support/concurrency/load_interlock_aware_monitor.rb:25:in `block in synchronize'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.2/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `handle_interrupt'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.2/lib/active_support/concurrency/load_interlock_aware_monitor.rb:21:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/connection_adapters/abstract_adapter.rb:721:in `block in log'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activesupport-6.0.3.2/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/connection_adapters/abstract_adapter.rb:712:in `log'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/connection_adapters/postgresql/database_statements.rb:90:in `execute'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/migration.rb:890:in `block in method_missing'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/migration.rb:858:in `block in say_with_time'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/migration.rb:858:in `say_with_time'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/migration.rb:879:in `method_missing'
/var/www/discourse/db/migrate/20200813090811_create_partial_index_on_post_search_data.rb:7:in `up'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/migration.rb:831:in `exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:9:in `block in exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in `exec_migration'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/migration.rb:812:in `block (2 levels) in migrate'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/migration.rb:811:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/connection_adapters/abstract/connection_pool.rb:471:in `with_connection'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/migration.rb:810:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/migration.rb:1002:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/migration.rb:1310:in `block in execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/migration.rb:1363:in `ddl_transaction'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/migration.rb:1309:in `execute_migration_in_transaction'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/migration.rb:1281:in `block in migrate_without_lock'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/migration.rb:1280:in `each'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/migration.rb:1280:in `migrate_without_lock'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/migration.rb:1229:in `block in migrate'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/migration.rb:1382:in `with_advisory_lock'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/migration.rb:1229:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/migration.rb:1061:in `up'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/migration.rb:1036:in `migrate'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/activerecord-6.0.3.2/lib/active_record/tasks/database_tasks.rb:238:in `migrate'
/var/www/discourse/lib/tasks/db.rake:215:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/2.6.0/gems/rake-13.0.1/exe/rake:27:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Caused by:
ActiveRecord::StatementInvalid: PG::DuplicateTable: ERROR:  relation "idx_regular_post_search_data" already exists
Caused by:
Tasks: TOP => db:migrate
I, [2020-08-18T14:41:26.914915 #1]  INFO -- : == 20200813090811 CreatePartialIndexOnPostSearchData: migrating ===============
-- execute("CREATE INDEX CONCURRENTLY idx_regular_post_search_data ON post_search_data USING GIN(search_data) WHERE NOT private_message\n")
I, [2020-08-18T14:41:26.915206 #1]  INFO -- : Terminating async processes
I, [2020-08-18T14:41:26.915423 #1]  INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/12/bin/postmaster -D /etc/postgresql/12/main pid: 50
I, [2020-08-18T14:41:26.915557 #1]  INFO -- : Sending TERM to exec chpst -u redis -U redis /usr/bin/redis-server /etc/redis/redis.conf pid: 167
167:signal-handler (1597761686) Received SIGTERM scheduling shutdown...
2020-08-18 14:41:26.915 UTC [50] LOG:  received fast shutdown request
2020-08-18 14:41:26.925 UTC [50] LOG:  aborting any active transactions
2020-08-18 14:41:26.928 UTC [50] LOG:  background worker "logical replication launcher" (PID 59) exited with exit code 1
2020-08-18 14:41:26.929 UTC [54] LOG:  shutting down
167:M 18 Aug 2020 14:41:26.964 # User requested shutdown...
167:M 18 Aug 2020 14:41:26.964 * Saving the final RDB snapshot before exiting.
2020-08-18 14:41:26.973 UTC [50] LOG:  database system is shut down
167:M 18 Aug 2020 14:41:27.299 * DB saved on disk
167:M 18 Aug 2020 14:41:27.299 # Redis is now ready to exit, bye bye...
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 3001 exit 1>
exec failed with the params {"cd"=>"$home", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
3cbb84d24b239cc6a7bd7c4eb6937c8b3e1e77613eee46a138a9815b627e8b9e
更新:以前のバックアップに戻してアップグレードを再度開始することで、問題を解決しました。
昨日と今日の間に変更した点は以下の通りです。
  • 「Site Feedback」の標準カテゴリ名とスラッグを改名し、新しい親カテゴリの下に配置しました。
  • 「Staff」の標準カテゴリ名とスラッグを改名し、新しい親カテゴリの下に配置しました。
  • 「Lounge」の標準カテゴリ名とスラッグを改名し、新しい親カテゴリの下に配置しました。
  • 警告テキストで提案されている通り、「Uncategorized」のテキストを編集して改名し、スラッグも変更しましたが、トップレベルのカテゴリのままにしました。
上記の変更は許可されていないのでしょうか?
更新:
