Updating AI plugin fails
Distilling this from Latest update won't build due to various reasons since that topic is about three different issues at the moment.
Problem:
When trying to update Discourse with the AI plugin installed, the update yields an error with
PG::UndefinedColumn: ERROR:  column llm_models.url does not exist
LINE 1: SELECT "llm_models".* FROM "llm_models" WHERE "llm_models"
and renders Discourse unusable until the AI plugin is removed.
When does this happen:
When updating an instance with the AI plugin
From a version that does not have the migration 20240514171609 yet
To commit 8d5f901 or newer
(My main question was why this only happens when updating an already-installed plugin and not when the plugin is newly installed. The answer is that core catches PG::UndefinedTable exceptions but not PG:UndefinedColumn. If the plugin is already installed then the exception is the latter, if the plugin is brand new then it is the former).
Reason:
plugin.rb calls LlmModel.enable_or_disable_srv_llm! which depends on the column llm_models.url being present. But if migration 20240514171609 (which adds that column) has not been applied yet, it crashes.
The problem is that db:migrate also runs this code, which crashes the rake task before the migration can be applied.
Suggested workarounds / fixes:
  1. change the code to LlmModel.enable_or_disable_srv_llm! if Discourse.running_in_rack? (so db:migrate does not call it)
    or
  2. change the code to LlmModel.enable_or_disable_srv_llm! rescue nil (so it does not crash)
    or
  3. change the bootstrapping code in core to catch PG::UndefinedColumn in addition to PG::UndefinedTable (so this and future similar issues are caught)
@Roman
Thanks for letting us know, @RGJ. I’ll take care of this and update once it’s fixed.
Pushed a fix here:
Let me know if you still have problems, please.
Works like a charm! Thank you :slight_smile:
