Beim Durchführen eines Upgrades in der Admin-Weboberfläche von 3.1.0.beta2 auf beta3, glaube ich, dass ich das Docker Manager-Upgrade erfolgreich abgeschlossen habe und dann das Haupt-Discourse-Upgrade wie folgt fehlgeschlagen ist:
$ yarn install --production
yarn install v1.22.19
[1/5] Validating package.json...
[2/5] Resolving packages...
[3/5] Fetching packages...
[4/5] Linking dependencies...
warning " > @mixer/parallel-prettier@2.0.3" has unmet peer dependency "prettier@^2.0.0".
warning "eslint-config-discourse > eslint-plugin-lodash@7.1.0" has unmet peer dependency "lodash@>=4".
[5/5] Building fresh packages...
$ yarn --cwd app/assets/javascripts/discourse $(node -e 'if(JSON.parse(process.env.npm_config_argv).original.includes(`--frozen-lockfile`)){console.log(`--frozen-lockfile`)}')
[1/4] Resolving packages...
[2/4] Fetching packages...
[3/4] Linking dependencies...
warning " > babel-plugin-debug-macros@0.4.0-pre1" has unmet peer dependency "@babel/core@^7.0.0".
warning "workspace-aggregator-0156df5c-af27-46bf-a6aa-a0a12748bb32 > discourse > @uppy/xhr-upload@3.1.0" has incorrect peer dependency "@uppy/core@^3.0.6".
[4/4] Building fresh packages...
success Saved lockfile.
Done in 20.00s.
Done in 44.16s.
$ LOAD_PLUGINS=0 bundle exec rake plugin:pull_compatible_all
discourse-data-explorer is already at latest compatible version
docker_manager is already at latest compatible version
$ SKIP_POST_DEPLOYMENT_MIGRATIONS=1 bundle exec rake multisite:migrate
rake aborted!
NoMethodError: undefined method `register_bookmarkable' for Bookmark:Class
Did you mean? registered_bookmarkables
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activerecord-7.0.4.3/lib/active_record/dynamic_matchers.rb:22:in `method_missing'
/var/www/discourse/plugins/discourse-data-explorer/plugin.rb:902:in `block in activate!'
/var/www/discourse/lib/plugin/instance.rb:503:in `block in notify_after_initialize'
/var/www/discourse/lib/plugin/instance.rb:501:in `each'
/var/www/discourse/lib/plugin/instance.rb:501:in `notify_after_initialize'
/var/www/discourse/config/application.rb:228:in `each'
/var/www/discourse/config/application.rb:228:in `block (2 levels) in <class:Application>'
/var/www/discourse/lib/plugin.rb:6:in `initialization_guard'
/var/www/discourse/config/application.rb:228:in `block in <class:Application>'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-7.0.4.3/lib/active_support/lazy_load_hooks.rb:92:in `block in execute_hook'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-7.0.4.3/lib/active_support/lazy_load_hooks.rb:85:in `with_execution_control'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-7.0.4.3/lib/active_support/lazy_load_hooks.rb:90:in `execute_hook'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-7.0.4.3/lib/active_support/lazy_load_hooks.rb:76:in `block in run_load_hooks'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-7.0.4.3/lib/active_support/lazy_load_hooks.rb:75:in `each'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/activesupport-7.0.4.3/lib/active_support/lazy_load_hooks.rb:75:in `run_load_hooks'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.4.3/lib/rails/application/finisher.rb:87:in `block in <module:Finisher>'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.4.3/lib/rails/initializable.rb:32:in `instance_exec'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.4.3/lib/rails/initializable.rb:32:in `run'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.4.3/lib/rails/initializable.rb:61:in `block in run_initializers'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.4.3/lib/rails/initializable.rb:60:in `run_initializers'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.4.3/lib/rails/application.rb:372:in `initialize!'
/var/www/discourse/config/environment.rb:7:in `<main>'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bootsnap-1.16.0/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:32:in `require'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/zeitwerk-2.6.7/lib/zeitwerk/kernel.rb:38:in `require'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.4.3/lib/rails/application.rb:348:in `require_environment!'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.4.3/lib/rails/application.rb:511:in `block in run_tasks_blocks'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/exe/rake:27:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bundler-2.4.4/lib/bundler/cli/exec.rb:58:in `load'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bundler-2.4.4/lib/bundler/cli/exec.rb:58:in `kernel_load'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bundler-2.4.4/lib/bundler/cli/exec.rb:23:in `run'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bundler-2.4.4/lib/bundler/cli.rb:491:in `exec'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bundler-2.4.4/lib/bundler/vendor/thor/lib/thor/command.rb:27:in `run'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bundler-2.4.4/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bundler-2.4.4/lib/bundler/vendor/thor/lib/thor.rb:392:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bundler-2.4.4/lib/bundler/cli.rb:34:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bundler-2.4.4/lib/bundler/vendor/thor/lib/thor/base.rb:485:in `start'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bundler-2.4.4/lib/bundler/cli.rb:28:in `start'
/var/www/discourse/vendor/bundle/ruby/3.1.0/exe/bundle:45:in `block in <top (required)>'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bundler-2.4.4/lib/bundler/friendly_errors.rb:117:in `with_friendly_errors'
/var/www/discourse/vendor/bundle/ruby/3.1.0/exe/bundle:33:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/3.1.0/bin/bundle:25:in `load'
/var/www/discourse/vendor/bundle/ruby/3.1.0/bin/bundle:25:in `<main>'
Tasks: TOP => multisite:migrate => db:load_config => environment
Docker Manager: FAILED TO UPGRADE
#<RuntimeError: RuntimeError>
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:202:in `run'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:101:in `upgrade'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:19:in `block in <main>'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `fork'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `<main>'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.4.1/lib/rails/commands/runner/runner_command.rb:43:in `load'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.4.1/lib/rails/commands/runner/runner_command.rb:43:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/thor-1.2.1/lib/thor/command.rb:27:in `run'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/thor-1.2.1/lib/thor/invocation.rb:127:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/thor-1.2.1/lib/thor.rb:392:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.4.1/lib/rails/command/base.rb:87:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.4.1/lib/rails/command.rb:48:in `invoke'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/railties-7.0.4.1/lib/rails/commands.rb:18:in `<main>'
/var/www/discourse/vendor/bundle/ruby/3.1.0/gems/bootsnap-1.15.0/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:32:in `require'
bin/rails:18:in `<main>'
Spinning up 1 Unicorn worker(s) that were stopped initially
Das Forum läuft, aber der Stand der Dinge ist unklar (für mich) - die Upgrade-Seite schlägt nun vor, dass ich bei latest-release +24 bin, dass docker_manager auf dem neuesten Stand bei e90c8f55 ist und dass Data Explorer die einzige Komponente ist, die ein Upgrade benötigt. Aber das Dashboard sagt immer noch, dass ich bei beta2 (b96869d5fb) bin.
Was ist zu tun? Meine beste Vermutung ist, ein CLI-Upgrade durchzuführen. Ich habe das Forum vorerst in den schreibgeschützten Modus versetzt.
